1 year old LG washer
We have a bad oder coming from our front loading LG washer. We've cleaned the filter and done everything that we know to get rid of the smell, but it's still there.
    Novelist:
    Champion:
  • 216 Answers
Greetings rh48192,
Are you using HE (High Efficiency) detergent in the unit? Most times the odor found in the units is because owners use regular laundry detergent instead of the low sudsing HE type. It is imperative that you use the proper detergent to avoid odor in your unit. Some of the fixes are to run an all bleach cycle with no clothes in the unit. Also, to leave the door to your unit open when not using it or at least cracked to allow the unit to dry out. Make sure to wipe out the gasket of the washer, sometimes trapped water there can also smell over time. Finally, there are some commercial products you can use to lessen or eliminate the smell. Here is a link to one product you can purchase at your local Best Buy™ store. http://www.bestbuy.com/site/olspage.jsp?skuId=8550249&type=product&id=1188560830483
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jun 24, 2008
I have had my LG front loading washer for over 5 years. I always leave it open to air dry after I am finished, usually for one to two hours. This past week I have noticed a mildew smell coming from inside...
you might want to try cleaning the washer using 1 cup of Clorox bleach, run it through the white or sanitary cycle, unless your machie has a clean washer cycle like mine does. Hope this helps.
Jul 11, 2011 | LG WM-2277HW Front Load Washer
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
My front load washer is making the laundry room smell with a really bad oder, why & what can I do to fix it?
Non HE detergent will cause your front load washer to have odors. If you do use HE detergent and still have the problem,use the "AFFRESH" product in the washer to neutralize the odor.
Oct 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Jan 15, 2009 | LG WM-2277HW Front Load Washer
Strong meldew smell from washer
Please take a look at the following link and see if you are following all the steps. Front Loaders are notorious for smelling this way , but there are things you can do to minimize the problem. I have owned a front loader for 8 years now and have never had a problem by following this advice.
http://www.fixya.com/support/r513372-front_loader_mildew_odor
May 16, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
