Question about Samsung HCN436W 43" Rear Projection Television
Convergence on SP43W6
Hello! Please, can you tell me, how can I enter into the service menu on my Samsung SP43W6? The picture on the TV is very bad, and the autofocus don't do that thing better. Sorry for my bad english, just I now learn the language.
  • 1 more comment
  • andyeast5 Jul 28, 2008
    well it looks like ive got the same problem with daughters tv looks out of focus but auto focus not doing its job coming up to 66% focusing white and red out of tilt and that the writing too if anyone can help id be grateful thanks
  • maffia_akose Aug 09, 2008
    Please i have this problem with my Samsung rear Projection tv.the pictures are in ghost form so i order 2 STK 392-040 and have it fix on the board,after that the screen has now open and the pictures are now abit ok just red colour is too much,i check on the ic and notice that one of the STK is hot.So please i like you to advise me on what to do next and where can i order original parts.
  • Anonymous Aug 20, 2008
    konvergen ancur
With the TV off, press MUTE - 1 - 8 - 2 - Power
Posted on Jul 10, 2008
Sony kp-53xbr45 please let me know step by step how to enter convergence service thank you
To enter into the convergence service of your sony, follow the steps below;
  1. Press "Menu" on the remote control. Use the up- or down-arrow button to move the cursor to "Setup" and then press "Return."
  2. Use the up or down arrow to move the cursor to "Convergence" and press "Return." This will bring up the convergence-adjustment screen.
  3. Press the up or down arrow to move the cursor to the line you want to adjust (either vertical or horizontal for red and blue) and press "Return."
  4. Press the up or down arrow again to move that line until it converges with the center green line and press "Return."
  5. Repeat to adjust the other lines until all three lines converge and are seen as a white cross.
  6. Press "Menu" to exit the convergence menu and return to the original screen.
You can as well follow these steps;
  1. Press the "Power" button to turn your TV on.
  2. Wait at least 30 minutes before you adjust the convergence in your television. This allows your TV ample time to warm up before you make the adjustment.
  3. Turn your TV to a cable channel or to an antenna channel with a picture that you can see. A music channel with a static shot of music notes isn't the kind of picture you need. Instead, look for a picture like what you would see on a movie, sitcom or drama.
  4. Press the "Flash Focus" button located in the front panel on your TV. You may need to open a hidden compartment on the front of your TV to access this button. The convergence will repair itself automatically after you hit this button. It may take several minutes.
Any of the two processes are detailed steps on how to enter your convergence service.
Take care
Jul 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Samsung:pcl4515r
You may still one more resistor opened , samsung most of the time its 2 low ohms but can be 3 it will be same value as other 2. I think they are 2.7ohms or 3.9 How to Enter Service Menu for convergence Turn TV off Press Mute 1-8-2-power now you should be in convergence use vol- and vol+ to select an item Use mute and menu to adjust when done Press ADD to save adjustments made.
Dec 12, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Convergence alignment problems with akai ph4298hd
After replacing ics did you ck for opened resistors low ohms 1.5ohms etc...You must get print out of How To Enter Service Menu for convergence it will tell you which numbers control which colors to move up and down to complete alinement for convergences. You must have your hand unit the one that came with set It has all the controls you need to be able to enter service menu!I will check to see if i have How to enter service menu.for this set.
Dec 12, 2008 | Akai PT4298HD Rear Projection Television
Samsung HCN4226W Rear Projection TV
You can get the convergence board by clicking here.
The service manual you might buy it from the same place.
May 23, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung SP43W6 convergenge map NEEDED PLEASE (HELP)
you press mute 1 8 3 on remote, be cearefull you can crash your set.
Mar 05, 2008 | Televison & Video
Service Manual for sp43t8-hex/shi - convergence problem
My sp43w6hpx needs the red pulled back in any one help with service manual
Dec 21, 2007 | Samsung HCN436W 43" Rear Projection...
Saving settings in service menu
Hi, I have a similar problem too on the SP47Q7HF. That one the lower level to match the red, and blue. Turn off the tv, and then restart, and still the colour runs off. Do you have a manual on the service mode adjustment? Or where to upload this info? I would like to try and adjust it. Thks
Sep 19, 2007 | Samsung HC-P4752W 47" Rear Projection...
Need akai pt4799hd setup code
Do NOT attempt to enter the service mode to align convergence if you cannot align the convergence with the user's menu. If the convergence cannot be corrected with the user's menu, it means that one of your convergence IC's has burned out and possibly burned out the fuse next to it. If you change any settings without first replacing the bad parts, you will only make things much worse. I believe that set is actually a Samsung, and has the 2 convergence IC's on their own board mounted above the small signal board. If you do not know how to identify and replace shorted convergence IC's, allow a qualified tech to handle it for you.
Sep 03, 2007 | Akai PT4799HD Rear Projection Television
Samsung HCN436W 43" Rear Projection Television Logo
251 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
