Question about Tappan TGF320 Gas Kitchen Range
Tappan Millenia Range
F3 is displayed on screen when I plug it in.
I keep it unplug because it beeps all the time.
Thanks,
Anna
  • Anonymous Nov 11, 2008
    MY OVEN CONSTANTLY BEEPING FOR RESTART AND NOW IT IS ON SELF CLEAN LOCK BUT OPEN
  • 794 Answers
Hi ChrisNess,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. If wiring is ok, replace the oven temperature sensor (RTD)
Hope this helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
I have a tappan range that keeps getting F1/F3 in on the display panel.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Mar 03, 2010 | Tappan TGF363 Gas Kitchen Range
Continuous warning Beep & "F3" displayed.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Jul 22, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
F3 flashing on display screen..no buttons work!
I have the same problem. However when I unplug the microwave from the wall outlet, let it sit for 10 seconds, then weird codes appear on the top line. Reset the clock and it shold work just fine.
zayd4@aol.com
Apr 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
OVEN SHUTTING OFF, CLOCK FLASHING
ve continually had the same problem for years. Now the display flashes F1 and beeps continually and I have to keep the unit unplugged. I can use the burners and manually light them but the oven is unavailable because there's no power.
Mar 29, 2009 | Tappan TGF657 Gas Kitchen Range
Microwave keeps beeping & has "f3" on screen
This will cost some money. its a total control fault. this means the control board is failing to initiate the commands. this is due to major micro board separation. the internal programming is ruined. it will have to be reprogrammed and a new board Will have to be installed. its best to purchase a new unit. this repair could run you into the 300 dollar range.
please rate and god bless..
Mar 17, 2009 | Ovens
When using oven it beeps and displays f3
Could be one of 2 problems. Perhaps both.
Unplug the range.Access the control panel and unplug the ribbon connector from the control.
Wait 35 seconds and re-connect it.
If it continues to beep and code replace the temperature sensor.
Mar 15, 2009 | Kenmore Ovens
Unlock my Tappan Gas Over Door?
Hi wewada,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Aug 03, 2008 | Tappan TGF320 Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan tgf355 oven door won't unlock and has code f3
open the back and manually spin the motor for the latch arm it may need to be replaced
Oct 31, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
488 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
