Question about HP Computers & Internet
Help since we have had our computer which is about 3-4 months it has been freezing up on us a lot. when it freezes you can shut it off the proper way you have to turn off the power strip. what could be the problem???
    Novelist:
  • 121 Answers
It sounds like you have a software issue with windows and that is what is causing yoru computer to freeze. If you would like to get rid of this issue you can re-install windows with the CD that came with your computer. If you decide to go this route it will erase everything on your computer so backup anything you do not want erased. What you will need to do is put in the windows CD and restart the computer. The computer will now boot from the windows cd and you will be prompted asking if you would like to install windows. Good luck and keep me posted.
Thanks - Tech101
Posted on Jun 24, 2008
For the last month or so when logged into facebook on my playstation 3 it takes fotever to load anything and freezes my system when i shut it down?
Here is why!!!!! The PS3 is NOT a very good computer, and trying to run web pages like Face Book on the PS3 is very buggy. Sometimes it will work, others, it won't. The reason being, you can not update Adobe Flash on the PS3, and therfore, not able to run a lot of the flash objects found on the page.
Aug 05, 2014 | Sony Playstation 3 (PS3) Console
FREEZER WILL DEFROST AND THAW OUT FOOD. THEN WILL START FREEZING AGAIN IN A COUPLE OF DAYS. THIS HAS HAPPEN 3-4 TIMES IN LAST 6-8 MONTHS. WHAT COULD BE PROBLEM?
seal around freezer door may be warped/old/cracked... or thermostat is not working properly.
Try duct taping door as tightly shut as possible and check around the time it freezes to see if that fixes the problem. If so, the seal (that has magnets so it will seal completely) needs to be replaced.
If that doesn't fix the problem, it could be a faulty thermostat in the freezer.
May 27, 2014 | Frigidaire Freezers
Why does curser freeze with windows 7
Computer freezes is usually related to hardware, meaning the video card, random access memory (RAM), or another component may be underperforming. Software also can lead to a frozen computer, as can issues with drivers, the operating system, and malware; A virus or spyware infection on your computer might also be the source of freeze issues.all these things can stop a computer from working properly.
1.If the freeze happens every time a certain hardware device is plugged in or switched on, the device itself might be to blame. Check drivers update for the device, and download and install them to erase any bugs that might exist in your version. Similarly, if the freeze only happens when using one particular application, that program might also be the root cause.
2.Run the System Restore utility from the System Tools section of the Accessories folder on the Start menu to roll back Windows to a previous version of the registry. This will fix prior registry issues without affecting personal files and settings.
3.If your computer still keeps freezing up after you take the solutions above, I suggest you to download a software to deal with it. The choice is sure to be more effective and simple, but there are few free utilities for this issue. Windows Boot Genius is a excellent one if you wanna take this solution.
source:http://windows-repair.net/computer-freezes.html
Jan 07, 2013 | Computers & Internet
My 18 month old computer freezes for about a minute .
could be 100 problems. but the pricipal ones are, moisture, very high fragmented hard drives with lot´s of junk files and bad system configurations. next time the computer freezes let him freezed for one or two hours and see if any activity happening on the hard drive. try open the pc case and very gently clean the rams, cpu cooler and the rear fans.
Jun 18, 2010 | Acer Aspire™ T180 PC Desktop
Freezing when I install a micro sd card into my samsung eternity
i had the same problem. so i try whatever i can
- i remove battery, put it back on, turn the phone back on. seems like it works for 3-5 minutes and freeze again
- i remove sim (only ),memory card still in there, and turn the phone back on..let it sit with no sim. and 3 minutes later it freeze again
- i remove sim, remove micro sdhc, reset the phone , the phone automatic restart..it woks... it never freeze ( no sim+ no memory card )
- i put the sim back on, no memory card, turn the phone back on and it works!!!!!!! i try these 2-3 times without memory card. works normal!!!
so..i think its a memory card issue. may be the phone doesn't like it. i have 2gb. kingston. or i have to buy a new card again.
for now its still working without freeze up for shut down by itself.
hope it help :)
moo
Jul 16, 2009 | Samsung Eternity Cell Phone
My airconditioner lines keep freezing up
Your filter is plugged, or the refrigerant is low, or it is getting too cold outside overnight (less than 60degf)
1) The two most common causes of insufficient air flow are dirty filters and under sized ducts. A dirty filter limits air flow which in turn allows the cooling coil’s temperature to drop below freezing. Replacing the filter, monthly, usually alleviates this problem. Under sized ducts will also cause the system to freeze
Because it also limits the amount of air flowing over the cooling coil. This results in lowering the coil temperature and allowing the humidity in the air to collect on the coil and freeze.
2)Refrigerant charge. The refrigerant system teeters on a delicate balance. If the system is not charged correctly, the system will not function properly. This malfunction may result in the poor cooling output and/or freezing up. Only a qualified, certified service technician can properly test and charge a refrigerant system.
3) Outdoor temperature. If night time temperatures are too low, the system will not operate properly, and freeze up may occur. The outdoor unit does not function well in temperatures below 60 degrees F. A special “ambient temperature” control must be installed to allow the unit to run properly in cool temperatures, or you may open your windows and save energy.
Jun 05, 2009 | Heating & Cooling
Doors keep freezing shut in michigan weather
From you description I suspect water is getting into the door latch. Then it freezes and stops the latch from moving properly. The solution is to keep the water out and the best way to do that is to make sure all the rubber seals around the window and door are working properly and in good condition.
Dec 22, 2008 | 1996 Buick Regal Olympic Gold
Ilo freezes
Try this...
1. Open up your My Computer Icon to show your drives installed on your computer and take note which ones are installed. Leave this window open.
2. Connect your ILO device and wait for the two additional movable disk drive to appear in your My Computer window (ex:
removable disk drive [E:], removable disk drive [F:])
3. Right click the first drive that appears (ex: [e:] if the removable drives show as [e:] and [f:]) and select format
4. Click "start" on the format window
5. Disregard the warning notice that pops up
6. Once that is complete retransfer all of your music and then
your device should function properly.
Jan 26, 2008 | iLO (2 GB) MP3 Player
Laptop freezes
"I never shut it off " Hope u r hibernating the laptop.. It seems that ur lap is junked with a lot of registery files and starup files.. so it takes a lot of memory to perform its operations and subsequently it hangs up.. and i hope u have installed norton anti viurs. this antivirus needs a lot of resources. better u install Mcafee. The best thing u can do is to install a fresh copy of windows. this will solve ur problem.. and remember keep the startup items to the min level.
Sep 03, 2007 | HP Compaq Presario V2555US Notebook
Computers & Internet Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
