Question about E-Machines eMachines Desktop PC
E machine steady beep black screen
  • David Needham
    David Needham May 11, 2010
    Is there a pattern to the beep code? If it is simply a steady beep, it is more than likely a video chipset error. Install a known good video card (probably have to be a PCI video card) and see if you get video of any kind.
  • 981 Answers
Power off at back of machine
replug cards
replug CPU
replug memory
repower
still beeeeep; then power off back and reset BIOS settings via jumper
still a beeeep; then go out for a drink or try another videocard
i meet more girls' videocards thanks to beeeeep.
Posted on Jul 27, 2008
How to stop steady beeping of treadmill
Paul, simply unplug the machine from your wall, witch is recommended from the factory.
Nov 18, 2014 | Exercise & Fitness
Toshiba will not boot
It needs those things to start up. If you reinstalled them in the machine and it won't start up you need to check some things:
Does the screen flicker when you power it on or does it stay completely black? If it stays completely black, then the connection from the screen to the computer itself is lost. Normally it is caused by a broken cable.
If the screen flickers and then goes black, then check the following:
Does it beep at you? If it does, then the amount of beeps is important. It will state in the users manual what that numbers mean.
If it doesn't beep, then my best guess would be that there is something wrong with the power distribution in the machine.
Sep 07, 2014 | Computers & Internet
Black screen beeping
Might be an issue with RAM.
Mar 20, 2014 | E-Machines eMachines Desktop PC
When i play a video the screen turns black and the pc hangs. after that when i restart the pc it beeps 1 long beep followed by 2 quick ones and the screen is still black
hello, turn your machine off and:-
  • You need to check your machine's RAM.
  • Make sure its well fixed.You can remove and fix it again correctly.
  • Check the hard disk's power.
  • Start machine and try playing the video now.
Hope it helps.Thanks!
Sep 25, 2011 | Gigabyte Computers & Internet
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
My desk top pc is steady beeping
if on power on u see nothing and just hear beeps and see blank screen with no text/signs of bios loading then my firend
ur RAM is faulty try replacing them and then tell me i can solve ur problem
hard disk comes after RAM if ur RAM is faulty ur system will never boot up and will give u beeps just disconnect the hard drive cable and check it ur selves if it boots to bios
pls ask for more help u want
regards
pls do rate me fix ya if i fixed ur problem
Mar 02, 2009 | E-Machines T2042 PC Desktop
I have a Brother Fax-920 which gives an 8 beep error signal. What does this mean and how do I fix it?
Spoke to the manufacturer and he said 8-beeps at a steady pitch indicate a problem with the sending fax machine not with mine.
Jul 15, 2008 | Brother Office Equipment & Supplies
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
C51gm m
I had this problem. It was a continuous series of slow beeps. It was a memory problem. I swapped the memory and the system booted.
Sep 13, 2007 | ECS C51GM-M Motherboard
E-Machines eMachines Desktop PC Logo
69 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
