Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Paper folds and jams before
BEGINS TO COPY AND PAPER IS FOLDING IN AREA WERE AND THEN A PAPER JAM. E2 SEEM TO NOT BE FEEDING INTO SECOND STAGE OF COPYING
I have a Xerox Workcenter XD 100 which gives me E2 error and paper gets crumpled under the fuser assembly. I opened the fuser area and didn't find any broken gears but there is a rectangular 1 1/2 by 10 1/2" plastic piece with a feed slot in the middle which evidently came out when I recently changed the toner. Where should this piece be installed? Is there a diagram that I can follow?
  • swedishrose Oct 06, 2008
    I have an older XD199 so Xerox no longer gives support. always worked fine, but started folding paper about 2 inches down from top and machine would jam. It does not go thru diffuser so ink smears of what is copied. There is a small green "thing" about 1 x 1 1/2 inch with 2 small black bars on it. This has come off. I cannot find pictures large enough in book in the diffuser or clear paper jam area to see where it belongs. Please help I do not want to throw away the machine as I still have a pricey ink toner cartridgfe.
    Problem Solver:
  • 8 Answers
Your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Posted on Aug 26, 2008
Paper jams when folding 8 1/2 X 11 ivory paper; less often with white. Tech says it's a paper issue - so whose colored paper (brand) will work - or is it a design flaw?
Is this paper the same weight/thickness as the white paper?
Are you specifying the settings properly as far as the weight and type?
It sounds like the sensors are detecting a double feed(?)
Try different settings for the tray, and even try a different brand of stock to verify.
Apr 29, 2009 | Konica Minolta bizhub C450P Laser Printer
Our Pitney Bowes 1810 Folding Machine hums & the document dial for the folding style does not move! Help!
Problem is not fixed. It does not involve a fax machine, it involves a Pitney Bowes 1810 document folding machine. Not interested in paying for "service" - it appears as though your service would be of any help.
Thank you
Jan 26, 2009 | Office Equipment & Supplies
Ip4300
Took a can of Blow Off (dust remover) and blew through paper track, and used a paper towel soaked in Isotope Alcohol and rubbed the tracking rails..
Everything seems to work fine for now except the canister paper holding is not feeding properly and the paper is getting jammed when you try to use it. This is not that important as long as paper can be fed the normal way and it doesn't jam..
Jul 12, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
ERROR E2
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
May 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
ERROR E2
The most likly problem by far, it a broken fuser drive gear.
That would be in the area where is says caution, heated surfaces.
Look on the inside, back side of that assembly, and you will find a gray/black gear either broken or with some teeth missing. You may even look inside toward the back on the frame and see pieces of that gear broken. Either that, or one of the stripper fingers on that roller are bent down blocking the paper in that area..
Mar 12, 2008 | Xerox WorkCentre XD120F Laser Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
242 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
