Question about Cuisinart DCC-1200 Coffee Maker
Weak coffee new coffee maker and no matter what I do, the coffee is very weak.
  • rdibbs Feb 16, 2009
    I have the same problem. This is my second cuisinart coffee machine.
  • Cuisinart Master
  • 19,396 Answers
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Posted on Apr 01, 2009
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Saeco Vienna Deluxe -- Coffee weak weak weak
When the coffee is weak, that is often because the water is not at adequate temperature.
Check if the coffee is in right quantity and pressed in the right way. If it is than it means that the water was not hot enough.
Check water temperature, if water is completely cold, the element mus be replaced, if water is hot, but not enough, then replace thermostate activating the pump.
Posted on Oct 13, 2008
mc1bean
  • 3053 Answers
SOURCE: no matter how much water
Hello, treasuremanI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
Weak Coffee
First think to check is the spray head which pours the water onto the powder. remove the spray head, clean it and soak it in descaler.
reassemble and do a brew. When finished check the surface of the coffee has 6 dimples where the water has poured onto it and that the coffee is uniformly wet. If no dimples or dry spots, get replacement spray heads.
Jul 27, 2013 | Bunn VPS Coffee Maker
Oct 13, 2008 | Saeco Vienna De Luxe Espresso Machine
My tassimo coffee maker is ruining the coffee it taste like water
i too had this problem BUT it was AFTER i descaled it and did the cleaning, now coffee tastes weak, and ive tried different discs (other coffees) and all come up weak.
Nov 13, 2011 | Bosch Tassimo TAS 4012 Coffee Maker
My Platinum Keurig says it is ready to brew but nothing happens. I have cleaned out any coffee grounds.
My B70 has worked good for about 6 months. Lately it won't brew a full cup of coffee or water for that matter. I have run Limeaway, and also vinegar throught it but nothing works. It seems to me the pump is too weak to make coffee before an apparent time-out occurs.
Dec 15, 2010 | Keurig Platinum B70 Coffee Maker
Our Bunn coffee maker has worked great for two years, but all of a sudden when we go to make coffee, the water pours out FAST and not the normal slow drip and the coffee is weak weak weak...we have cleaned...
It sounds like you are missing your sprayhead. If you will call Customer Service at 800-352-2866 with the model we will be able to send you out a new sprayhead.
Aug 18, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Saeco Italia coffee too weak - grindes too coarse
Remove beans from chamber, then remove the 2-3 screws in the chamber, then lift hopper slightly and turn adjustment knob towards the middle number, or halfway between fine and coarse. Then lower hopper make sure the gears line up together, set screws add beans and adjust finer.
Oct 08, 2009 | Starbucks Saeco Italia Digital Barista...
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
Coffee is too weak/light
I think I have the right manual. Page 29?
http://products.saeco.com/articolo.asp?id_linea=1&id_articolo=740823049
Jan 01, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Coffee Grind
After you change the grind, how many cup of coffee have you make?
Oct 24, 2007 | Saeco Magic De Luxe Espresso Machine
Cuisinart DCC-1200 Coffee Maker Logo
1,053 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
littlechum55
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
