Question about Optoma RD65 65" Rear Projection HDTV
Mirror adjustment Do you have a diagram that will illustrate adjusting it so I can do it myself? The rack assembly is straight forward but I don't know where the mirror is. Thanks again.
  • 979 Answers
No, I'm sorry, I do not. However, you should be able to see the objective once you have the wave guide/reflector chamber open....accordianman
Posted on Jun 24, 2008
Freezer door won't close tight
There should be adjustments in the hinge assembly. Go to Jen-Air .com, then select parts. They will have diagrams to view for repair, adjustment etc.
May 06, 2014 | Jenn-Air JCD2389G Side by Side...
Memory seats adjust on there own as well as mirrors
BCM has nothing to do with this function , MMM - memory mirror module !
Memory Mirror System Operation
The MMM is capable of storing mirror position for 2 different drivers. Mirror position is determined by both horizontal and vertical position sensors in each of the power mirrors. The MMM supplies a reference voltage and a low reference to these sensors and determines mirror position through the horizontal and vertical position signal circuits.
The MMM receives power through the battery supply voltage circuit and the MIR/LOCK fuse and a constant ground source. Any time that battery voltage is disconnected and then connected from the MMM, the MMM will enter the mirror relearn mode. The mirror relearn mode can also be commanded using a scan tool. Refer to Memory Mirror Module Learn for further information.The memory switch receives power through the battery supply voltage circuit and the MIR/LOCK fuse. The MMM upon receipt of a memory switch signal input, a class 2 message from the SIC or a class 2 message from the PCM indicating that the transmission is in park, will then supply battery voltage and ground to the appropriate power mirror motors through the mirror motor control circuits to move the mirrors to the predetermined positions.
DTC B1586, B1596, B1616, or B1626
The mirror horizontal and vertical position sensors are potentiometers. The Memory Mirror Module (MMM) provides these sensors with a 5 volt reference circuit and a low reference circuit. The MMM monitors the horizontal and vertical position sensor signal circuits which change values based on mirror position. These voltage values are used to determine mirror position and can be set into memory. When the MMM receives a memory recall request, the MMM will control the power mirror to the memory position based on the horizontal and vertical position sensor signal values.
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Memory Mirror Module (MMM) data list.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Memory seat module
• Memory mirror module
• SEAT 25A circuit breaker
• MIR/LOCK 3A fuse
Your best bet , take it to a qualified repair shop !
May 23, 2017 | 2002 Cadillac Escalade
My 1998 Dodge Grand Caravan Sport had the driver's door electric mirror forced forward and now will not stay in the proper position...(nothing appears to be broken)can it be fixed or will it need to be...
There are plastic gears in the housing that motors use to adjust the angles. If they are stripped then you need a new unit. The mirror comes off by pulling it straight and away from the housing and snaps back in.
Aug 26, 2013 | 1998 Dodge Grand Caravan
The racks all fall out if even the slightest weight is on them, very scary keep waiting to burn myself badly
Hello Kathy Manson - Unfortunately, based on the symptoms you are describing, the oven liner would need to be replaced. The oven liner cannot be adjusted or shimmed to resolve this issue. If I was in your position, I personally recommend consulting an experiencing service technician to assist with the repairs.
Mar 04, 2013 | Electrolux 30" Built-In Single Electric...
I don't know how to change the head light on my 1997 Jeep grand Cherokee. there doesn't seem to be any screws to loosen the light.
Hi Clint,
I just want you to know that you are not crazy or blind!
The reason you cannot find any screws is because you are dealing with a snap-together vehicle.
If you only want to replace the bulb, you can reach around the radiator support and twist the bulb retainer to remove it and the bulb. If you are wanting to replace the ENTIRE headlamp assembly, follow the instructions below.
REMOVAL
Grasp lower edge of headlamp lens and pull straight back (away) from Grille Opening Reinforcement (GOR) . Disengage lower adjuster pivots from lens assembly.
Grasp upper edge of headlamp lens. Pull straight back (away) from grille opening reinforcement (GOR). Disengage upper adjuster pivot from lens assembly.
Rotate bulb lock ring counter clockwise. and remove ring and bulb from lens.
INSTALLATION
Replace by seating the assembly in the lamp housing and turning the lock ring 1/8 turn clockwise to secure.
Align upper adjust pivot into headlamp opening and snap into place.
Snap lower adjuster pivots into place.
Oct 16, 2011 | 1997 Jeep Grand Cherokee
How do I remove the interior panel so I can get to the mirror assembly screws?
The right outside mirror is just bolted on the door with three nuts. Remove the panel on top the door panel and then remove the insulator behind there and then you can get to the nuts to remove the mirror.
You will have to place your fingers behind the old mirror as far back as possible in the center and pull the old mirror straight off. Then inspect the clips where the new mirror will clip on the housing for any damage. Align the new mirror up with the snap-fit hooks with the adjuster mechanism ramps. Gently press the mirror on the adjuster mechanism with the palm of your hand and pressing in the center of the mirror. Using the palm of your hand you should rotate the glass about the glass pivot until it snaps into place.
In addition to the chat, hope this helps (remember to rate this answer).
Dec 31, 2010 | Chevrolet Astro Cars & Trucks
I need a diagram for the rear drum brake for 2002 Ford Ranger
Copy and paste this into your search window: 2002 ford ranger rear brake diagram
You should see four pictures pop up, select the brake parts diagram or the brake picture.
Sep 03, 2009 | 1993 Ford F150 SuperCab
Control Review Mirror. Being able to adjust it
Where is your side mirror adjustment knob? If you turn the directional straight up to 12:00...That adjust your rearview mirror.
Sep 08, 2008 | 2002 Mercedes-Benz S-Class
Side mirror replacement
go to a junk yard as it'll be a lot cheaper there... Yes, technically you can just replace the backing and mirror. The backing is connected to the housing via two rods and some clips. The rods are (secured to the backing and these adjust the pitch of the mirror). If these rods become separated, then it may be tricky to adjust the mirror. Then again, adjust it once and it should stay
Jun 15, 2008 | 2000 Honda Accord
Top Rack always slides out fully
Well, you are right on about the level. It is tilted just slightly forward. The only parts to go bad are the plastic ball bearing guides, and usually when they go, you get a rack that wont come out and gets jammed. You 've got the problem, you just need to remove the screws hidden in the holes that are sometimes coverd with rubber plugs so that the dishwasher may move freely, andjust it till it no longer rolls out, then screw it back to the counter to hold it in place. There are no springs in that rack, so either its still tilted forward, or the tank is bowed or bent somehow, and that would mean new dishwasher. Hope this helps!
Jun 19, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Optoma RD65 65" Rear Projection HDTV Logo
Top Optoma Televison & Video Experts
jasbo
jasbo
rostit
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
