You have most likely caused one or more fuse relays to blow.
The self-clean operation can not be interrupted before the cycle is complete without causing issues.
There is the main fuse inside the control panel and 2 fuse relays on rear of the oven.
In order to access these fuses you must open the door,then remove the mounting screws to remove the oven from its cabinet..
Use a wire coat hanger bent into a "U" shape on one end.
The door latch is in the center of the door on the top oven.
Slide the bent wire coat hanger between the door and the oven opening.
The "U" of the coat hanger will be right center of the door latch.
Slowly pull the "U" to the left until it catches the latch.
Then pull steady and forcefully to pull the latch mechanism to the left while putting pressure on the door to open it.
Once the door is open you can begin to access the parts for diagnosis and repair.
Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
