Question about Refrigerators
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet around freezer door are quite warm although the ambient temperature is neither hot nor especially humid. This refrigerator has functioned perfectly up until the past week.
  • bkbkbkt Jun 27, 2008
    Turns out the motherboard had failed and was not sending voltage to the cooling fan, but I guess not the first time GE has had this problem as they replaced the board for free and waived the service call fee even though the unit was over a year old. BTW, the online scheduling for an appointment, as well as the service call itself could not have gone any smoother. Thanks for your help.
    Novelist:
    Champion:
  • 216 Answers
Greetings bkbkbt,
Many times this behavior is an early indicator that your unit either needs freon or might have a compressor issue. I would advise contacting a repair person before this problem gets worse.
Thank you,
Dorothy
Go Ahead. Use Us.
Posted on Jun 24, 2008
GE bottom freezer PF22missaww i came home from vacation and it was at 60 degrees , unplugged it for 10 minutes and plugged it back in , ran fine for a month , came home from work and the unit is warm again...
GE Profile bottom freezer erratic.
GE Profile Bottom-Freezer Refrigerator with Electronic controls with digital temperature readout (Should include Models PDS20MFS, PDS20SFS, PDS22MFS, PDS22SFS, PDS22MFS) May also apply to other models.
Diagnosis: Search of Internet yielded no definitive fix. It appeared to me that the some minor frost buildup might be symptomatic of unseen frost elsewhere. The electronic controls could possibly be messed up.
Fix: Not knowing whether it was frost or the electronic controls (or both), did the following:
1. Turned off the refrigerator. (It is not clear how to do that. Download the owner's manual for your model from the Internet. If it is like mine, the freezer and refrigerator APPEAR to have separate controls. In fact they are linked. To turn both freezer and refrigerator off, press the WARMER button on EITHER the refrigerator OR freezer until the display shows OFF for both the freezer and refrigerator.)
2. Unplugged the unit. Let it set for 18 hours with both doors open.
3. Plugged it in (which may have reset the electronic controls.)
4. Turned it on. To do so, I followed the instructions that said to press the COLDER button on either the refrigerator or freezer. Press the same COLDER button a second time and it should go to the factory presets of 0 degrees for the freezer and 37 degrees for the refrigerator.
5. Allowed the temperatures to stabilize for a week, after which temperature adjustments can be made.
Jun 13, 2017 | Refrigerators
Variance in freezer compartment temperature
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
Sep 04, 2009 | GE GSS20IEM Side by Side Refrigerator
Not maintaining set temps but holds steady at 31 and 61
Could you double check your model number the number above your post is nothing like the refrigerator2.gif you are describing, Thanks, Sea Breeze
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 10, 2009 | GE PDS22LBN Bottom Freezer French Door...
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Jun 17, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Refrigerators Logo
194 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
