Question about Brother LS-2125 Mechanical Sewing Machine
I have a Borletti 1102 Sewing machine.Recently whilst in use, it laboured a bit then stopped.I opened the pedal and fiddles with the 'contacts, also oiled some of the points on the machine and it started to work again for some 15 mins then stopped again.I feel the problem lies in the pedal but I cud be wrong. When I do press the pedal after 'adjusting the contacts', I need to push/coax the wheel. It works for abit then stops. Help!
  • 323 Answers
SOURCE: The fabric doesn't move forward.
We need to do some examining. Remove the foot. Put the stitch length dial at the longest stitch. Turn the wheel and see if the feed dogs move about 1/4 inch. Also check to see that they rise just slightly above the needle plate. If it does these two things it will work. If the teeth don't rise above the plate, remove the needle plate and clean the lint out from between the rows of teeth. If you find a lot of tightly packed lint there this will solve your problem. Reinstall the needle plate and foot. If the feed dogs don't move about 1/4 inch, you probably have a problem which is going to require the services of a technician.
Posted on Jun 12, 2008
SOURCE: Wrong type of stitch/tension not working
Found a solution to my own problem.... hope this helps someone else. Make SURE the bobbin case is seated correctly! (follow the instructions carefully). Don't put the cover back on right away after you put the bobbin case in. First check and make sure it doesn't move when you turn the hand wheel.
Also, when threading the bobbin make sure the thread passes down through the tension adjusting spring of the bobbin case.
Posted on Aug 24, 2008
  • 9 Answers
SOURCE: how to adjust the thread
Here is the user manual from which I will quote
Page 19 has how to adjust the tension of the thread
There should be dial to which you can turn to adjust up or down your tension , use a piece of scrap fabric to ensure it is set at the right tension that you need ..
The upper thread tenison wheel is located on the left side of the machine above the needle ( top/front of machine shown on their diagram of the machine as #5 )
Posted on Sep 17, 2008
SOURCE: sewing machine Brother Cs-6000i don't work
let me know too, mine won't turn on, worked just fine yesterday, Suz
Posted on Jul 06, 2009
  • 4 Answers
SOURCE: I own a Sears Kenmore machine that began sewing backwards
Make sure that the reverse button isn't stuck inside. if all else fails, go back to sears and have them look at it.
Posted on Oct 16, 2009
How do I open top part of my sewing machine
all machines need some oil at some point in their lifetime . try contacting the manufacturer thru their website .
Jun 22, 2016 | Bernina Bernette 75
My sewing machine does not stop from sewing when I get my foot off the pedal
one or more of the electronic components is failing . I would contact customer service for the make and request a new foot pedal
Mar 04, 2015 | Sewing Machines
Where to buy a drive belt for borletti 1102 sewing machine
Nov 17, 2014 | Sewing Machines
My Aunt gave her D'lite sewing machine. It sews correctly but will not stop sewing unless you unplug the cord. The start and stop button will start the sewing if not using the foot pedal but it will
There's a possibility that your foot pedal is sticking; if that is the case, it's probably overriding the stop button. See if you can take the cover off and clean it using alcohol, and leaving it open for a couple of hours to make sure it has dried. Visually check the wires while it's open, too, to see if you can see any fraying, and make sure the plug on the machine side is firmly seated in the machine.
Sep 14, 2014 | Sew D'Lite Sewing Machines
Maching starts without using foot peddle
"Ghost sewing" sometimes occurs when the wires inside the foot are making contact before the pedal is even used. There is sometimes a "dial" on the bottom of the foot pedal (usually accessed through a small hole with a miniature flat bit screw driver) that can be fine tuned for responsiveness. If the dial is labeled + or -, turn the dial toward the minus to reduce the responsiveness of the pedal, (should be counterclockwise) and if it is not labeled just try quarter turns until the pedal operates as is should. If there is no adjustment, you may have to open and repair or replace the pedal.
Apr 09, 2014 | Simplicity Fashion Pro SW2145 Mechanical...
My machine continues to run after i take my foot off the pedal.
Undo the foot control and take out the little square bit called a suppressor which you don't need these days anyway and it should be fine.
Jan 19, 2010 | Singer CE-200 Quantum Futura Computerized...
I have a singer 514. I recently got a new foot pedal. When I press the pedal The machine motor runs hard, but nothing happens without moving hand crank -- and it will stop "whenever"
Sounds like you need to open the foot control and adjust the carbon bar, you will soon see it, just undo the screw and move it away from the contact or adjust the screw in the end.
Sep 12, 2009 | Singer Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
370 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
