Question about RCA Televison & Video
I recently purchased an RCA rear-projection TV from a friend, and I'm having some trouble with the convergence. It's model # P60925BL, serial #904251165. When I try to use it, the red and blue convergence are really off. Every image appears in three seperate colors, and the picture as a whole is warped, kind of fish-eyed. I've gone to the screen options in the menu, and if I click on either the red or blue convergence options, it fixes it for a whiloe, but it doesn't stay fixed. Any suggestions or tips would be greatly appreciated. Also, any opinion on whether this problem is worth fixing, or if it means the TV is shot. thanks
  • RCA Master
  • 8,617 Answers
Since two colors are affected I would suggest checking the solder on the convergence power supply. If the solder is good you will most likely need a new power supply. The power supply board is the one without all the heatsinks next to the convergence board
Posted on Jun 24, 2008
"Adjust Projection TV" missing from Screen menu
Convergence problems on RCA sets are common. You can get the parts and DIY instructions from www.TvRepairKits.com
Apr 20, 2013 | RCA P52945 52" Rear Projection Television
RCA Projection TV Model P60925BL. Has sound but lamps don't turn. Chassis model PTK195LC
i went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Dec 11, 2009 | RCA P60921 60" Rear Projection Television
Cant find convergence on menu screen
The HD61LPW42 is a RCA DLP which doesnt have convergence. If the convergence is out of alignment you have a three CRT TV such as the D52W19, HD52W59 RCA Check the model number from the rear tag and let me know what the model number is.
Nov 21, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
RCA 60" Rear Projection TV Model P60925bl TV screen curved on the top and bottom. Colors are not aligned and images are blurred.
this would be the convergence IC 's that need replacing
if you are going to have a tech come out to do the repair it will cost between 3 or 4 hundered dollars
if you are going to do the repair yourself ( meaning that you can solder and indentify the convergence chips and test the resitors on it) then it will cost about $40 or so
electech
Nov 27, 2008 | RCA P60921 60" Rear Projection Television
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
1080i connection has green hue
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Rca 52" projection tv...d52w20
You could have a bad red tube or the socket on the tube may be bad; completely different from convergence
Dec 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence
Replace (2) STK392-150s these are your convergence ics.
Nov 12, 2007 | RCA P52928 52" Rear Projection Television
RCA Home Theatre Model # P56927, Serial # 026451246
your convergence alignment is off,requires reaignment or possible replacement of module,this type of rca projection tv has a fault with the harness feeding the convergence module there is a fix for it,contact you local rca dealer,they must replace the connector because it bows and looses connection over time that creates other faults also/
Aug 22, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
