Maytag mfr30pncts commercial washer
I have a maytag #mfr30pncts commercial washer that when it's turned on the main menu comes up on the digital display and I can't get out of it to start machine. I tried turning it off for 10 min. and turning back on but the main menu still comes up
  • 1073 Answers
SOURCE: Electrolux 1087 E90
call frigidaire for factory service or have the dealer replace it
Posted on May 09, 2008
  • 36 Answers
SOURCE: Maytag MAH20PD washer does not do the High Spin Cycle
with what you have described the problem should be in the door lock unit. there is a check switch that gets pressed down and sends a signal to the computer board telling it that it is locked. if the switch isn't working then that signal will not be sent and the washer will just turn and never enter spin. replace the switch and this will clear up the problem
Posted on Jan 03, 2009
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Posted on Apr 16, 2009
SOURCE: washing displaying OE error code
Just resolved same is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Posted on Apr 26, 2009
  • 111 Answers
SOURCE: Maytag commercial automtic washer displaying an F1
CUSTOMER CONCERN: Customer has F1 Error Code. The control is sensing an error in the signal from the air pressure sensor circuit. CAUSE: CORRECTION:
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed. A) Air leaks in the air pressure (switch/sensor) hose. a. Inspect the hose for cracks, pin-holes or loose connection. b. Replace the hose and harness assembly if it is compromised. B) Moisture in the air pressure (switch/sensor) hose. a. Inspect the hose for evidence of water. b. Replace the hose and harness assembly if water is detected. C) Lint or flashing in the air dome hose connection port. a. Inspect the air dome hose connection port for lint or flashing. b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub. D) The control needs to be replaced. a. Replace the control only after you have completed steps A – C above, and verified that there are no issues with the air pressure system.
Posted on Jun 18, 2009
How do I reset/clear error codes F20 and F21 on my Maytag commercial washers?
Try to turn off power for 2 minutes and fool the washer into thinking it is new vs suffering a water loss. If that doesn't work see if there is a reset button on the mother board.
May 16, 2016 | Maytag Washing Machines
How does the maytag top load commercial washer remove lint
never knew washers did it . dryers have lint filters not washers
May 15, 2015 | Maytag Washing Machines
Maytag Coin Washer can't select Cycle after putting in coins
check the coin mech
If it is turning on properly
check the selector itself.possibly the switch
Mar 18, 2015 | Maytag MAH21PDD Commercial Front-Load...
Maytag commercial front load washer MAF18MC3AS has 3 rinse cycles. can this be changed to 2 rinse
No. unfortunately, this is a preset situation. this is programmed into the main logic sector on the control. It is preset during manufacturing, and cannot be changed.
Nov 13, 2009 | Washing Machines
Program computer-Maytag commercial washer mat12pdbaw
Try going to this website and scrolling down to find your Maytag Model number. Click on the model number and the programming steps should come up for you.
Apr 14, 2009 | Washing Machines
Is the maytag MAH21PDD commercial wash worth buying ?
I would have a look at the machines and give them a spin by hand to see if there is any noise in the main bearings or if possible get the owner to run a load through the machines and listen to the noise they make they should not sqeal or make a grinding noise.Also check the boot seals for mold or for any tearing.
Feb 16, 2009 | Maytag MAH21PDD Commercial Front-Load...
Maytag washer cleans poorly & has been making loud sqeeking noise
The drive Belt is loose adjust it's tension or change with new one.
Jan 09, 2018 | Maytag SAV3655A Top Load Washer
Blowing fuses
if you have a friend with a multimeter then you can trace the fault backwards from the plug to see when exactly the short circuit happens without plugging the machine into the mains using the multimeter terminals as the mains terminal and advance the timer by hand to see where the short accurses on the dial so you can see weather the short is the heating element or not that's the main cause of short circuits eric
Dec 26, 2017 | Maytag Commercial Non-Coin Washer,...
Maytag MAH21 - main motor won't run
Please check microswitch block door/ Best result change this microswitch on the new. If terminal is shot - longered on wire.
Rashid Moscow (
Dec 19, 2007 | Maytag MAH21PDD Commercial Front-Load...
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
