Question about Maytag Dishwashers
Maytag dishwasher won't drain..
Quiet series 100 model #MDB 5600 will wash but not drain. I do not even see where the drain is.. I don't want to start taking things apart until I talk to someone. I don't want to call a repair person and have them charge me $75 to pull a plug that I am not aware of. Please help
  • Anonymous Mar 15, 2014
    Water will fill and continue to overflow to drain until reset. Have replaced cycle timer.
  • 487 Answers
Please find attached DRAWING This will give you an idea how to tackle this
Posted on Jun 24, 2008
Not draining. fills, then smells Maytag quiet series, 100
there is clog in your main drainage line, you are smelling the decay of your food, rinse off your dishes before placing them in the dishwasher
Jul 22, 2010 | Maytag MDB5100A Dishwasher
My Maytag Qriet Series 100 Dishwasher won't drain
Check the drain hose connection at the sink drain for local blockage. If ok, you may have to tear down the lower spray arm assembly down to the deck (noting orientation and position as you remove parts). Look for clogged screens and clogged openings in the deck. You can use a vacuum hooked to 'blow' to make sure these openings are clear. Wash the screens in hot water, detergent, and white vinegar to remove water and food deposits. Make sure upper and lower spray arms have open spray holes and no split seams. Hope this gets you running again!
Feb 10, 2010 | Dishwashers
I have the maytag quiet series 100 dishwaher, the washing cycle works great until it gets to the draining then i hear a low humming for a couple of minutes then the diswasher just shuts off, can you offer...
take the hose off that goes to the air gap
get a bucket and put the hose in it
put the unit into drain
does the unit drain?
I am assuming that you have a garbage disposal
please let me know
Jan 08, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 100, Model # MDB5600AWS, built in dishwasher. Does not get the dishes clean, dishes stay dirty after multiple cycles of washing. Please help!
We also have a Quiet series 100 and had the same problem, the dishes always came out dingy or with food all over them. My washer is about 5 years old and worked well for about 4 of them but the last year has been doing a poorer and poorer job washing the dishes. I finally broke down and removed the racks and all of the plastic parts from the inside of the washer. Doing this revealed that the groves in the under side of most of the plastic parts was clogged with food and debris. After a good scrubbing with water and a brush then reassembly it worked like a new washer again, cleaning the dishes very well and the best part is it saved us about $700.00 for another washer.
Jun 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water does not drain completely, mostly but not completely and just stays there Maytag Quiet Series 100
If the machine has a auto sensor or auto clean cycle it is supposed to keep water in the bottom. The sensor has to stay wet for it to work properly. My Maytag drains, then fills slightly to do this.
Jul 03, 2008 | Maytag Dishwashers
Mdb 6600aww
i need your serial num its important
Oct 19, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
938 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
