I have a Ricoh FT6645 that displays SC343. It has not been used in quite some time. Is there a real problem is is it a simple reset? Also, I have no users manual fo rthe copier. Where might I find one?
    Master:
  • 788 Answers
It would seem that an SC343 code indicates that the waste toner collection bottle is either missing or not positioned correctly.
Posted on Jun 24, 2008
Resetting sc542 error
Fusing thermistor defective or out of
position
• Fusing lamp open
• Fusing thermostat open
• Fusing thermofuse open
• Power supply board defective
and for reset use prog 5-810 as follow
Resets all level-A service call conditions, such as fusing
errors. (To reset SC 547, switch the machine off/on.)
[0 = No / 1 = Yes]
• After selecting "1", press the Original Type key and the
' key (or OK key) at the same time to execute the
reset. If the reset is successful, the display shows
"Action completed." If the reset fails, the display shows
"Error!!!".
Apr 22, 2014 | Ricoh Aficio 1018D Copier
Error sc543 sp c320dn
SC542, SC543, SC544, SC546,
These codes are related to fuser temperature. Make sure that power source voltage are not low. check thermisters, fusing lamps etc. To reset this code press "All clear" yellow key, enter 107 and press the red key for some seconds. Sevice mode will be displayed, enter SP 5-810 (SC code reset) and select "1". Then hold down the Photo mode key and the # key at the same time for at least 3 seconds
Feb 17, 2012 | Ricoh SP C320DN AllInOne Laser Printer
Infotech is 2127
"I want, I want, I want".....I bet you do!
First, learn how to ask for things nicely ....but repair manuals are NEVER part of the deal
Quit messaging me!
Nov 27, 2011 | Ricoh Office Equipment & Supplies
Hello, I have a Ricoh 1160L Fax machine and I
my fax is ricoh1160L.This fax always one fault 'CRU fuse error'show the display
Jul 20, 2011 | Ricoh FAX1160L Plain Paper Laser Fax
Error code sc542 on ricoh spc222sf?????????????????
Press the red CLEAR/STOP key till you hear the little beep. Press 1 0 7 Press the green COLOR START key. The display changes into MAINTENANCE MODE Use arrow keys to go to ENGINE MAINTENANCE and hit Ok Use the arrow keys and select FUSER SC RESET and hit Ok Hit OK again at the Execute prompt.
Once it is done executing the reset, power the unit off and on.
If the error comes back again, it is likely a real hardware problem and you may need to replace some components.
Sep 30, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
We have a Ricoh Aficio 350 copier that is quite old but has worked well through the years until now. It keeps displaying ADD TONER and runnng after we have already put in a new cartridge. Under add toner,...
take the toner supply unit out. toner supply unit is one where toner bottle fits and vacummed clean the unit. the toner unit is blocked. i am a Ricoh technician.
Sep 23, 2010 | Office Equipment & Supplies
My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Feb 18, 2010 | Ricoh Aficio SP C811DN Laser Printer
Ricoh aficio 1515mf photoconductor reset
Found some information here:
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
Try the following
press the yellow “C” button
enter 107
press the red “C” button and keep it hold till the display changes
turn the power off with the big red switch on the front side
turn power on again.
OR
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Jun 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh FT6645 - FULL USED TONER, CALL SERVICE
Well, it's going to be messy, but the waste toner is a big, tall container, clipped into the bottom right side of the machine(where the paper feeds up the side. Remove it ,and get yourself a big plastic bag, and start dumping. WARNING: There is no easy, clean, way of doing this. That's why it is typically removed and replaced with a new one, but go for it, if you feel up to it.
Apr 06, 2009 | Ricoh Office Equipment & Supplies
Gestetner #3470
The model number of your machine doesn't match up with anything I've seen. I'm thinking that it's a machine built by Ricoh and if so, that S/C 320 indicates that the polygon mirror motor has failed. If that is the case, it's going to be a costly repair as that part is burried way inside the machine and isn't easy to replace by the average layman. Sorry I couldn't be more help. I'm about 5,500 miles away.
Aloha,
Bill Monroe
Oct 17, 2007 | Office Equipment & Supplies
117 people viewed this question
jasbo
jasbo
