Question about Whirlpool LER4634J Electric Dryer
Dryer belt replacement
Hello, I am trying to replace a broken belt.
  • moodyb2 Jul 31, 2008
    I WANT TO REPLACE MY BELT AND CANT FIND IT
  • panhead053 Aug 02, 2008
    I have a whirlpool heavy duty supreme dryer. I need to see a picture of how the pulley on the bottom, or should i say tention wheel is positioned.
The belt will go thru the tensioner, then the lower part will just go aroune the drum and the top part will ride on the smooth section of that tensioner. If you ask me it is quite cheesy... but it seems to work! good luck.
Posted on Aug 15, 2008
  • 9 Answers
SOURCE: broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Posted on Dec 06, 2007
SOURCE: broken tumbler belt
Slide a putty knife or other thin object between the top and front panels a couple inches in from either side. Press in and release the two spring clips holding the top panel and at the same time lift it up and lean it back. Remove the screws inside the front corners holding the front panel on. Place the new belt around the drum in about the same position as the old one was. Remove the lower rear panel to access pulleys. place belt around the motor pulley. Stretch the idler arm over and place belt around pulley. Reassemble.
Posted on Jan 03, 2008
SOURCE: How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Posted on Jan 11, 2008
  • 7 Answers
SOURCE: Maytag electric dryer mod#DE612 series02
U might want to look on the back of the dryer to see if there is a panel to take off. If not the hole top will have to come off. Is the top made on the rest of the dryer or is there a split between it.
Posted on Nov 24, 2008
SOURCE: Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Posted on Feb 09, 2010
Dryer does not turn but heats up fine
That sounds like a broken belt..if you removed the smaller panel below the main front panel very likely you would see the broken belt laying in the base
DISCONNECT POWER first though
This video shows how to disassamble that that style dryer to replace that belt
http://www.youtube.com/watch?v=APlWrIcP94g&playnext=1&list=PL7F004559A84354DB
I hope i have been able to help you fix your dryer,
GENE
Aug 26, 2011 | Whirlpool GEW9250 Electric Dryer
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Dryer heats up, but tumbler won't turn.
Hello awe.... when the dryer heats but doesn't tumble it is due to a broken dryer belt. It is always a good idea to replace the idler pulley when you replace the belt.
IF you want to do this job yourself you can see a schematic and order the parts at searspartsdirect.com
Joe
Feb 22, 2011 | Maytag Dryers
Dryer not rotating but machine is running
Hello & Welcome to FixYa
The problem can either be with the dryer belt that is either worn out or broken and needs replacement. You can take it apart and check before replacing the belt. Please get back to me if you have any other questions.
Kevin
Jan 15, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My dryer squeaks terribly
Squeaking sound from the dryer comes when the belt is either broken or worn out, before replacing the belt also check the idler pulley because if that is bad then it also needs replacement with the belt. Please get back to me if you have any other questions.
Kevin
Dec 21, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Drum won't turn
Hello wrorth...... generally when the dryer drum won't turn the belt is broken. It is generally a good idea to replace the idler pulley when you replace the belt. If you want to do this repair yourself, you can buy these parts at Searspartsdirect.com
Just enter your model number and the schematics of your machine will pop up. Which will also show you how to open it up to replace the belt... Joe
Thanks for choosing Fixya!
Dec 03, 2010 | Whirlpool LEQ9857L Electric Dryer
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
Drum does not turn
Here are a few things to check. If you don't feel comfortable performing these check, please have a repair person come in and check it.
* Broken belt. Open dryer and see if belt is still wrapped around the drum. Pull on the belt to make sure it's not just hanging there. Inspect belt condition. Do not apply spray adhesive in this case: replace the belt. If belt is broken, look for contributing causes for failure such as worn drum rollers, damaged felt kit, or stiff idler roller.
* Motor burned out. Remove belt from motor pulley and start dryer. If motor runs but is noisy and motor is unable to turn the drum when the drum belt is threaded back on the motor pulley, then replace the motor.
* Thermal fuse is open. Run continuity test.
Hope this helps.
Sep 10, 2009 | Kenmore 63942 Dryer
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Mar 11, 2009 | Danby DCD5505W Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
