FixYa.com
Tags:
BenQ PB6100 Multimedia Projector
Problem With Benq PB6100 the Red Lamp Light keep... (by 2 users)
posted by BenzKK on Jun 24, 2008
About 8 Out of 10 times when I turned on my PB6100 Projector the Fan started to run in a very high speed for a few second then The Red Lamp Light keep Flashing and turn itself off after another few second. It's this a Lamp Problem? Do I need to get a new Lamp? I've used this lamp only about 350 Hours. So could anyone plaese help me about this? Thanks a lot.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by augmrao, posted on Jul 13, 2008
i had a similar problem within 1 yr and called and asked for repair/replacement by the benq and I was suggested to send it to the maintenance division which i did. it camd back and was working fine for a while. But then once again the problem repeated. though i made an attempt without much of success.
please suggest what i should do. I believe this problem comes when you use it for long hours.
GANJI
Can you Help with these Multimedia Projectors problems?
Benq PB6100 blank screen
My Benq PB 6100 projects a... Answer This...
Hi there
Did you ever find out the... Answer This...
dust in the lens mechanism
i have problem with dust in... Answer This...
Cleaning dust and dirt from the...
How do you safely clean the... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
