Question about Vehicle Parts & Accessories
Clifford wont cherp
Hi
Can you help me to get my clifford intelliguard 950 alarm to cherp again when someone gets to close to the car . the sensor is still working and setting the alarm off but the warning cherps are not warning people that its armed.
Thanks
Paddy
    Problem Solver:
  • 5 Answers
Refer to the owners manual your LCD screen should have a menu/setting/etc. type of thing to help set back the chirp..
Posted on Jul 16, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
GTI. How can I get my Clifford alarm to operate the central locking?
My best advice is to contact clifford direct and explain your problem normally very helpful.
Mar 02, 2016 | Seat Ibiza Cars & Trucks
Looking for troubleshooting assistance as to reason why vehicle will not start..
There is likely a relay installed in the circuit for the starter crank form the alarm/immobilizer. The contacts on these relays will arc when mating and separating due the large current being drawn by the starter. This will cause pitting on the contacts and result in a voltage drop (thus the 9V). This voltage is not sufficient to engage most starters. Locate and replace the defective relay.
Jul 08, 2015 | G5 IntelliGuard 770 P/N 919621 Car Alarm
I have a Clifford G4 Intelliguard 750 that activated while driving. It does not reset with the remote and I don't have the Pin Code. How do I deactivated?
You are going to have to disconnect it. This is pretty basic, if the immobilizer circuits are wired you'll need to identify the 2 pairs in the 4 way plug and bridge them out, if they're not used just unplug the control box. You can get an installation manual /wiring PDF here.
Dec 31, 2014 | Vehicle Parts & Accessories
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
My Viper Alarm started going off while I was driving. I pulled over, shut everything off. Got out of the car and closed the door and locking and unlocking the vehicle wouldn't shut the car off. I opened...
The alarm may not be going off. Rather it may be a malfunction of the relay that is driving all the sirens and piezo. Next time it happens check for flashing parking lights. They will flash only when alarm is going off. Also ignition input to the alarm prevents this alarm from going off while driving. Panic from the remote can still be triggered. Got to play detective....
Feb 27, 2017 | Viper Vehicle Parts & Accessories
Clifford alarm
check the internal battery of the alarm as it may be getting low on charge.
May 30, 2013 | Vehicle Parts & Accessories
Clifford intelliguard 950. Won't work properly
Find the manual that came with the system, it will tell you how to reprogram the system after a battery change, these systems are famous for killing batteries if the car is left sitting and not started.
Oct 14, 2012 | Cars & Trucks
The indicator light (blue) on the sensor that attaches to the windshield is flashing repeatedly. My remote is also not working.
Hi ,sounds like a Clifford well known for problems would suggest calling an alarm specialist for you alarm,but usually cheaper just to have a new alarm fitted.
Aug 06, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
348 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
