Question about gossip Watches
Need to shorten a band
I have a CHEAP Gossip acrylic watch with a link band and a fold-over/snap closure. It is way too big, how do I shorten it. It looks like I have to open the closure where the pin is and remove some links or move the pin down the plastic "cap" over the closure. ???? Pick one or make one up of your own.
Kathy in Redondo CA
    Problem Solver:
  • 14 Answers
If you want to shorten your band then you should go to watch store in your vicinity, they will advise you in a better way.
http://streetlegaltshirts.com/movies.html
Posted on Dec 03, 2013
  • 2,071 Answers
You better pick one and size it according to your size, if not enough, pick one again to other side of the band in order to balance ,,until reach the size you want....
Posted on Jun 24, 2008
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I bought the self adjustable bracelet watch but do not know how to adjust it to make it tighter on the wrist
Self-adjusting bands usually feature easy to remove links that simply snap out. They usually look just like the main clasp or blend in with the band. Simply locate these links and undo the closures to remove or add them.
Aug 20, 2010 | Timex 2J611 Watch
My dog chewed the glossy croco band on my Gossip
www.WatchBandHQ.com
has a large selection of bands.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 11, 2009 | Watches
I need to shorten the flex band and I can not find how to take the links out.
If you have never done this you will likely break the first one you try; don't be discouraged.
Call some jewelry stores to see if there is anyone competent in sizing expansion bands (most likely an independant jeweler is your best bet as they only hire experienced jewelry professionals where as most chains they just hire whoever will work for the least money and no experience required).
If you are set on frustrating yourself here's how you size it.
1. fold down top and bottom tabs on both sides of band with a flathead screwdriver or similar.
2. move down the bracelet the number of links you wish to remove and fold down the top and bottom tabs there as well.
3. remove links (they will slide out)
4. reconnect the band with the small "U" shaped springs using a tweezers.
5. Fold down the metal tabs to enclose the springs.
6. lightly tap with hammer to make sure the tabs are flush and secure.
Oct 17, 2009 | Avalon Ezc Low Vision Talking , Gold Tone...
Need to shorten the flex band on one button watch
Shorten watch band
For this you will need a pair of fine tweezers, a small flat blade screw driver and a lot of patience.
Determine how many links you need to take out by pinching the band while it is on the wrist. Once you know how many you are ready to remove the links.
spread the band and you will see that the very end of the links is tabbed. Be careful and fold down the end of the link with your small screw driver. Be careful not to bend anything. You will then need to turn the band over and bend down the tab of the link on the opposite side but right beside the first tab you bent down. Now you will see how the band is held together. If you look into the two tabs you just bent down you will see a small peice of metal connecting the two links. This is a staple. Pull the staple out with your tweezers.
Now go to the exact opposite side and perform the same task. The band should now be apart where you remove the staples from each side.
Now count down the number of links you want to remove and perform the task again.
*Remember that you must do it the exact same way on each side or the band will not go back together.
Once you have the correct number of links out the band will go back together the same way you took it apart.
When folding down the tabs be sure to use gentle even pressure so you dont over bend them and keep the band from moving freely. I usually find it easiest to use the fla part of the screw driver in a gentle pressing motion.
Remember that this take watch makers and technician a lot of practice. Be patient. If you arent patient or good with very small parts, pop into your local jewlery store for help.
Sep 17, 2009 | Timex 27191 Wristwatch
Replacement acrylic watch band
I posted the other same request...all I've been able to find is ceramic replacement bands, and nothing clear. These run about $200.00 and for that price we should just replace the watch with a "Toy" which it is copy of...
Jan 18, 2009 | Anne Klein 10 7977MPTT
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Need bands
try the gossip web site or google it you mite get some on ebay. hope this helps joe
Nov 20, 2008 | gossip Rectangle Case Leather Strap Watch
Shorten watchband
I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
Mar 30, 2007 | Timex Outdoor Casual Expedition®...
Watches Logo
350 people viewed this question
Top gossip Watches Experts
Jimmy Accardi
Are you a gossip Watch Expert? Answer questions, earn points and help others
