Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
Right Hopper not Chilling
The right hopper is not chilling.
  • caffiends Aug 17, 2008
    The right side of my granita machine is not chilling either.
    It is the middle of summer and I NEED both of these!!!
    Please help! The screen is saying right torque sensor error.
    Any ideas?
  • annie belle Sep 15, 2008
    President:
  • 1,618 Answers
There could be one of 3 things:
1- The temp sensor on the back of the machine is not working.
2- The auger may be damaged.
3- The pins on the shaft could be covered with product.
Posted on May 20, 2009
  • Ernest R
    Ernest R May 20, 2009
    On the torque sensor error there is a small board on the back of the machine it is inline with the shaft, after you clean the shaft pins check the red and white light that the pins cycle between make sure there is no produst on them.
  • Mitchell Campion Feb 20, 2011
    There is only one compressor and gas system in the 2 bowl slush machine and a solenoid is used to open and close a gas valve to chill the bowels independently. Swap over the solenid valves to see if the fault follows the solenoid.
Hi does anyone know anything about the frutina slush machine. Ive just bought a preowned one. Im not sure its working right and it didnt come with instructions. Thankyou
Well I live in Southampton, and Ice Frutina are based here. The liquids come in great big containers that you just pour in ready mixed I think (or perhaps its from concentrate, I'm not sure) but either way the mixing instructions should be on most slushie mix containers. For the machine to make slushie you basically need two things to happen...
1) the powerful refrigerator within the unit should function and chill/freeze the liquid in the hopper
2) The agitator should be constantly turning inside the hopper to break up the ice crystals as they form turning the liquid into slush rather than just a block of solid ice.
If the refrigeration is working, you should notice a pretty quick drop in temperature of the liquid in the hopper... It may be worth checking any fans are working properly and not seized up. Check the refrigerant compressor is humming.
That's about as much as I can help you I'm afraid. Hope it ends up working for you :)
Jan 07, 2017 | The Kitchen Appliances - Others
How can adjust faint dark adjustment?
open the front door, remove mounting screws of toner hopper at top right corner, flip open hopper cover, slide out hopper , above the drum unit in center there is corona assembly, detach connection of corona cleaner, on the right side of corona assembly there is a black plastic lock, loosen the screw and slide lock upwards, slide out corona assembly, on the upper side of corona assembly there are clear plastic adjustment screws, if u want to make copies darker- turn all of four screws evenly counter clockwise and if u want to make copies lighter- turn all of four screws evenly clockwise.adjust half turn every time and check. revert whole process to put all together. make sure u connect hopper connector at the right bottom side of the unit after sliding in the unit.
Feb 10, 2011 | Canon imageRUNNER 6000 Copier
I amusing cannon ir6000 . the error indcation is -check hopper conetivity
I take that it is saying that the toner hopper is not connected to the copier??? The connector for the hopper is covered by a small cover with one screw. With the front door open look on thebottom right of the hopper, there is a small cover > make sure the copier is "OFF" > remove the screw and you will see a white connector > make sure that the connector is installed & all the way in..... If that dose not do the trick, you may have a bigger problem....... Good Luck
Jan 26, 2011 | Canon imageRUNNER 5000 Copier
Machine cannot work properly and there's a message check hopper connector. what exactly hopper connector is?
that connector is located at the hooper assembly open the front door then at the right side of that machine remove the 3 screw of the hopper assembly then you will see the hopper connector maybe its not connected to the terminal jack just connect it then return all the screw you remove thats all
Dec 14, 2010 | Canon imageRUNNER 5000 Copier
I have an Ultra 2 bunn slush machine. One hopper
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
How do I replace photoconductor?
turn off the machine.open the front door. open the right door. remove the toner hopper. after the hopper is removed , remove the pcu connector. on the old pcu s a push tab. push the tab with your right thumb and pull the old pcu out. unbox new one. pull all tabs and paper off new one and install. put toner hopper back in. close all covers and turn on machine.
Dec 31, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
How to change toner
1.Rotate the toner bottom.
2.Open the hopper cover(located in the right side on display) and fit the b oss on the trip of the toner bottle in the grove of the toner supply mouth.
3.Pull the black shutter of the body to the right.Keep pulling until the shutter stops.
4.Pull the shutter of the toner bottle to the right.Toner will be supplied from the toner bootle to the hopper.Tap on the bottom of the toner bottle to make sure that all toner has moved to the hopper.
5.Push the machine shutter to the left until it stops.
Oct 23, 2009 | Canon NP 6230 Copier
Konica 2125 toner
The toner supply methode:
1.Rotate the toner bottom as shown ten times.
2.Open the hopper cover and fit the boss on the tip of the toner bootle in the groove of the toner supply mouth.Be sure to push it in until a click is heard.Ckeck to make sure that toner bottle is locked to the toner suplly mouth.
3.Pull the black shutter of the body found on the right of the toner supply mouth of the hopper to the right.Keep pulling until the shutter stops(is located in near right side of the display).
4.Pull the shutter of the toner bottle to the right,toner will be supllied from the toner bottle to the hopper.Tap on the bottom of the toner bottle to make sure thet all toner has moved to the hopper.Push the shutter of the toner bottle to the left to close.
5.Push the machine shutter until is stop.
Sep 01, 2009 | Canon imageRUNNER 5000 Copier
Olympia shredder 1280.6
On this model, make sure the hopper is all the way in. If it is, remove paper hopper and check to make sure the hopper is not broken. There is an electromagnetic switch in the front and the hopper has a magnet built in to it. run a stick magnet across the right underside and front to see if it extinguishes the light. If not, then the board is bad.
Jun 12, 2008 | Olympia 1280.6 Shredder
Adding toner
Inside the front cover on the top right, is there a toner hopper that swings out? From the looks of the repl toner, it should be a sealed hopper. When the cartridge is locked onto the hopporit will release the latch for the toner hopper. There are usually very simple pictures on the inside of the door or toner box.
Mar 20, 2007 | Canon PC1061 Copier
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
535 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Kelley Hopper
Jerry Greenberg
Jerry Greenberg
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
