Question about Sony Handycam DCR-TRV900E Mini DV Digital Camcorder
No signal, only blue lcd-monitor, when playing my footage, yesterday it was ok. also trouble with recording
  • 1 more comment
  • thfilm Jun 24, 2008
    The optical viewfinder is showing an image with five broad horisontal stripes.
    Collegues say that the heads may be dirty ? And that the trv900e has problems with showing images shot with fex a CanonXM2,  which is the case here.
    But I head problems with a new cassette as well, the tc starts at 00:00 at every take and I get no viewing of the takes. Dirty heads ?
    kindley regards
    Trygve Hagen
    shortfilm director
    thfilm@online.no
    No problems with the battery or power supply.
    The playback mis now ok. The heads probably dirty. I used the cleaning cassette.
    But still no recording signals on the new cassette. Could it be something wrong with the sey up, format or things like that ?
    trygve hagen
  • thfilm Jun 25, 2008
    I got no answer on the comment sent to me today. Why ?
    Trygve Hagen thfilm
    Brigadier General:
  • 6,966 Answers
A blue screen often indicates the absence of a usable video signal, in effect it is video muting. If your unit uses the Mini DV PAL cassette format, this could be brought about by dirty heads. Try cleaning the video heads. Often this would have to be done manually but you could also try if you can get a cleaning tape ( Mini DV PAL cassette format) that would fit your Camcorder. Dirty heads would affect both playback and recording. To confirm, you could try playing an old tape known to be good.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 24, 2008
  • Louie  Role
    Louie Role Jun 24, 2008
    Glad that for now the playback is working.
    This type of camcorder uses the same head for playback and recording and since it works on playback, it would be safe to assume that it would also work in recording. Since still issues during record mode, the problem lies elsewhere.
    As some camcorders have a built-in RESET button, check for a RESET button. Please refer to the Instruction Manual supplied with the camera for specific information regarding the availability of this button and its function. If there is no RESET button available, follow through the steps below to reset the camcorder.
    To Reset the Camcorder:
    1. Turn off the Camcorder
    2. Remove the battery from the Camcorder.
    3. Remove the AC Power Adapter from the Camcorder.
    4. Move the Camcorder power switch to the ON position.
    Note: Leave the switch in the ON position for at least 15 seconds.
    5. Move the Camcorder power switch to the OFF position.
    6. Connect the AC Power Adapter to the Camcorder.
    7. Turn on the Camcorder.
    Additionally, pls try a different brand of cassette/tape for your recording.
    You might find this page interesting if not informative.
    Brigadier General:
  • 3,614 Answers
Did you test if the battery was charged?
    Master:
  • 848 Answers
Have you checked your battery
    Master:
  • 788 Answers
Did you try resetting the camera by turning it off, taking out the battery and removing any other source of power? Try this first to hard reset the camera.
Does the optical viewfinder function or is it also blue?
Hopefully hard resetting will solve your problem but if not then there may be an electronics fault in your camera.
  • Dean Joly
    Dean Joly Jun 24, 2008
    If you record do you see the picture fine? Is you problem only during playback? If it's like that all the time then in my opinion you have an electronics fault you your most likely have to replace the main electronics board in the camera which may or may not be difficult to find.
  • Dean Joly
    Dean Joly Jun 25, 2008
    Ok, so playback is OK, good. Now, when you say there is no record signal going to the cassette, are you seen the image in the viewfinder and on the LCD? If so then the problem is with the recording mechanism or electronics. If you get no picture at the viewfinder either then the problem is either optical or with the processing circuitry.
Blue screen on lcd screen
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
Nov 11, 2010 | Sony DCR-HC30E MiniDV Camcorder
I have a Panasonic AG-HVX200. We use it record our services on Sunday. We recorded 4 times yesterday and when I go to play the video back it's just a blue screen. I have tried several tapes and it does...
try running a dry head cleaning tape for about 5 to 10 seconds. if it improves, but still has problems, run it again for another 5 to 10 seconds. There is a possibility that your heads were dirty when you recorded and therefore the footage did not record correctly. Hopefully, that is not the issue and the head cleaning tape will help.....Sony has the best one that we have found and we use it on all different brands of camcorders. If you need repair or further assistance contact us www.austintelstarservices.com
Aug 30, 2010 | Panasonic AG-HVX200 Mini DV Digital...
Half the screen is blue
the lcd panel is faulty. replace it at a service centre
Oct 13, 2009 | Sony DCR-VX2000 Mini DV Digital Camcorder
Mini DV Tapes are not playing back. Nothing but blue screen when I try to view tape...no time code...nothing. Recently recorded footage plays back fine though?????
If recently recorded plays back ok, and there's no warning about low rf or head clogging problems,it seems to be electronic problem in vtr board,but usually is head problem,which is not so expensive.
Jul 30, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Camera won't record/ play footage.
Video head was dirty / clogged due to old tapes usage so it did not recorded any signal on tape and now it requires cleaning with good quality head cleaning tape to record and playback properly.
May 31, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Cant play back recorded footage
you have to flick the switch on the side from camera to play
Jun 29, 2008 | Canon MV650i Mini DV Digital Camcorder
Playing back footage on pc
don't know u're cam, but usualy the camera haz to "close" the dvd sesion, so that the computer/dvd player .... to be able to play it ...
Ofecourse u can play the video on PC, using cd/dvd data recovery software, that accesses the data directly and not track based ... (that in the case that the dvd got damaged and the recorder can't finish it ...)
Feb 17, 2008 | Video Cameras
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Colour problem when recording with Panasonic NV-MX500
Hi, I recently had he same problem, you need to have the unit repaired, it is a small but extremely expensive part that has broken. If my recollection serves me right, it's the colour sensor. There are three that combine the colours to give natural colour. My repairer stated that vibration caused the problems to my camera. Good luck.
Jun 29, 2007 | Panasonic NV-MX500B Mini DV Digital...
Sony Handycam DCR-TRV900E Mini DV Digital Camcorder Logo
114 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
