Question about Conair HC111R Hair Trimmer
Worked fine the first time we cut hair. Now turns on but does not cut hair now. There is a gap between the cutters and the plate. I can move the adjuster and see the cutters slide up but they do not come in contact with the plate. Is that right?
  • zogpip Apr 11, 2009
    My Wahl dog clippers worked the first two times but now fail to cut the hair. The blades appear to be moving and we can't see reason why they aren't cutting.
    Problem Solver:
  • 13 Answers
Are the screws tight that hold the heads on? If so try an on old tooth brush to make sure there is no hair clogging them.
Posted on Jan 10, 2009
Trim sensor error
Dust may have accumulated within the moving cutter.
Clean the moving cutter.
For details, see "Maintenance (Cleaning around the needle plate)".
Jan 17, 2018 | Sewing Machines
Im having trouble with my Andis Master clippers. I tried doing a cut with a 1 1/2 and they wont cut. If I use just a one or any other size they are fine, only when I raise it to a half they don't cut.
get a small shallow dish and put in a small amount of kerosene
turn the clippers on and place the cutter blades( just the cutter blades ) in the kerosene so that any gunk , hair etc is washed out
change the cutter head to a newly sharpened set
Mar 10, 2017 | Andis Health & Beauty
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
License plate bolts spinning
Seems like a lot of trouble to remove the mounting panel. If you can get to the back of the panel you should be able to get a pair of grippers onto the nut. If the bolt spins there must be some gap between the back of the bolt head and the licence plate. Use the tips of a pair of side cutters ("hollow" side out) to immobilise the bolt then use a dremel with a cut off disc to cut off the head which lies between the jaws of the cutters. Of course if you have a really strong grip you might be able to cut off the head with the side cutters.
Jul 10, 2015 | 2010 Dodge Journey
Viking 936 Machine is not cutting fabric, but continues to sew. What can cause this?
More than likely the cutter/knives need replacing or are not coming up all the way to catch the fabric. Put a piece of fabric on the plate just before the cutters and turn the hand wheel slowly. Are the cutters coming up above the fabric and moving to below the fabric to complete the cut? If not, open the front cover/door and turn the hand wheel watching the cutters' movements. You should see the gears that travel up and down. Many times this area becomes packed with lint/fabric and binds the movement. I usually take a large needle and dig out the lint/fabric or whatever else is stuck in that area. You'll be surprised how much you will remove from that area.
Jun 20, 2014 | Husqvarna Huskylock Computerized 936
No pilot ignition, air is ok
Some times when I use my plazma cutter its a cut master 42 .I would some times have to turn it off and turn it back on for it to work .And here lately all it does is air come on and off its like its has a heart beat and then have to cut it off again . I have replaced the tips and electrodes .And nothing .I have took thee electrode out and clean the white dust build up and works fine for a little while
Feb 01, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
My motor is working but the top cutter will not move, I've taken it apart but it still wont move the cutter at all. The only time the motor moves the top cutter is when I unscrew it. What should I do?
The front tension is too tight loosen it a bit this may help, if not you need to send it in to have it check if the motor is still working with full power. check Mannys-Sharpening.com They can help.
Jan 28, 2011 | Andis T-Outliner Hair Trimmer
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
Plasma Cutters support
In this process, an inert gas (in some units, compressed air) is blown at high speed out of a nozzle; at the same time an electrical arc is formed through that gas from the nozzle to the surface being cut, turning some of that gas to plasma. The plasma is sufficiently hot to melt the metal being cut and moves sufficiently fast to blow molten metal away from the
Aug 27, 2008 | MILLER 192049 SWIRL RING PLASMA CUTTER
T-Outliner has stop cutting!
good advice but the best way to align is to know the exact aliment,pay attention to how the blades are set in relation to one another when they cut correctly,and remember this so that next time wont take so long to adjust the blades.
Mar 12, 2008 | Andis 01690 Hair Trimmer
Health & Beauty Logo
313 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
