There should be any loose solder terminals at the vertical sweep output section circuit. Check all the solder terminals. Re-solder all the suspected solder terminals.
Based on your concern, since you have a display issue (vertical line on the screen) I recommend to contact the technical support of Lenovo. They will set up a depot repair for you to diagnose the computer and to repair it completely. You may contact them at this number 1-877-4Lenovo (1-877-453-6686). --> Hours of operation, 24 hours a day 7 days a week
--> Your system came with a 1 year base warranty. Since you purchased the system last 07.02.2010 your computer is still in warranty.
I don't know if this will help as my printer is a different model (the epson stylus photo r280) but I have been battling the vertical line issue for weeks, ever since getting a new imac. I am printing altered photos from photoshop on epson ultra premium matte photo paper. After trying every conceivable setting, and spending an hour with less than helpful tech support from epson (where they insisted I needed to download new drivers) I just resolved it this morning at last by increasing the dpi setting on the print function to beyond what I would normally use(1440x 1440 rather than what I had been using at 720).
The prints came out great at last!
On my older computer with this same printer the prints came out fine at the lower setting. But for some reason it appears that the higher setting is now necessary to eliminate those dreaded lines.
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
