Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool gold accubake system stove/oven
When I got up this morning the clock part of my stove is flashing E1 F1. I have tried to press the "stop" button but the flashing keeps on. It will not let me start the oven or do anything. when I moved here there was no instruction booklet. How do I fix this
  • EdwTrg Sep 14, 2008
    my whirlpool Accubake System Super capacity 465 E2 F 1 Code keeps appearing oven won't stay going what is the problem I do not have an owners manual
  • epgraham Jan 21, 2009
    have a whirlpool gold accubake. The power went out in my house yesterday and since then the display is showing "e1 F1" as what I am assuming is an error message. I tried unplugging it today for about 6 hours in the hopes it would reset but I am still getting the same error message. WHen I push the buttons to unlock the controls and unlock the cook top it just beeps. When I push the off cancel button it goes to the time and "loc" display for a second then back to "e1 F1". In addition to all of that the cook top and oven will not turn on. It is gas. Any ideas?
    Sergeant:
    Champion:
  • 330 Answers
Can you unplug the plug for a while? Are you the new owner ?
Do you have home owner insurance?
Posted on Jul 10, 2008
I have whirlpool accubake model wle 3430 almost 10 years old and have a code E1 F1 and oven is not working ! 1 e
The F1-E1 error code means the control board has detected a problem within the control itself and the control board needs to be replaced
When ordering the control please note it may also be called the,CLOCK,EOC or Electronic Oven Control in addation to the control board..any of those names it will be the same part.
GENE
Sep 04, 2011 | Whirlpool Accubake SF362LXTS Kitchen Range
My Whirlpool Gold Accubake, smooth top displays E1 - F1 (blinking). I am unable to utilize the oven because the push-button/ touchpad does not work however the electric burners work fine. Any clue? Many...
Hello, Thank You for using FixYa. I will be helping you today.This is erc or control failure. You would have to replace the electronic range control sometimes called the clock depending on your model number
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Whirlpool Ovens
My oven is showing an F1-E1 error code. What does this mean
F1 - E1 EEPROM checksum error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
Oct 25, 2010 | Whirlpool Accubake RF362LXTT Electric...
E1 F1
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 31, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
After a power outage oven will no longer work
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
Jan 31, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Range GLP 85800 toop cook ok, flashing E1 -F1- and a few segments
Jan 26, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Oven has error E1 F1 will not work
F1 - E1
Jan 11, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven not working on wirlpool accubake system
I have a Whirlpool Accubake System stove / oven. About 50 p% of the time I go to push the "Bake" and "Start" button, it goes to "Cal" or "EO -F2-" what ever that is. It won't let me clear it . Needless to say I am not happy with the fact that when I go to bake something, the oven doesn't work!!! Please help!
Oct 15, 2008 | Whirlpool Kitchen Ranges
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
3,274 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
