Question about Acer Aspire 3100-1405 Notebook
Acer 3100 problems
I did a system restore, I then could not get the windows to come up fast. I then tried to restart in safe mode and now the system will not boot up. The monitor will not come on even through I see a flash of something. The computer will not boot up at all. All lights are on, but nothing.
Please help. It is a Acer 3100.
Erick
    Scholar:
  • 174 Answers
Try to reinstall the system and choose restore or repair option from the installation cd - i hope it will repaired by itself if it ask tp format means old os is fully corrupt if you need your data dont format, you may lose your data. remove the hard disk and attach to some system and take all your data the new installation
Posted on Jul 04, 2008
Acer
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. if this hails to fix the problem http://support.microsoft.com/kb/307545/ restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download you could select the option start with command prompt you should be in DOS mode black screen type chkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive you should have no input while chkdsk utility is in progress any input might further damage your hard drive
Apr 06, 2013 | Acer Aspire One Zg5
Computer tries to boot but keeps going back to the "how do you wish to start windows
Your operating system may be corrupt, you could try booting into safe mode to further troubleshoot or restore the computer by reinstall Windows or restoring factory defaults if that is an option.
Mar 01, 2011 | Acer Aspire 3100 Notebook
Windows does not shutdown properly, asks me if i want to restart in safe mode?
It never hurts to start in safe mode. While in safe mode, some things will not be available to you. Be aware that there is a reason your computer is telling you to start in safe mode. Something happened, hardware or software related, that caused a problem. Windows allows you to start in safe mode to correct problems. Not knowing what the problem was, I might suggest starting in safe mode, then go to start, all programs, accessories, system tools, then system restore. Try to restore your computer to a few days ago when it was working properly. Then restart, and hopefully it will work.
Aug 22, 2010 | Acer Aspire One PC Notebook
My acer computer keeps shuting itself down
Try tapping F8 at startup, and from the list of startup selections, select Safe Mode by using UP Arrow Key to go there > then hit Enter.
Try a System Restore once there, to pick a Restore Point before your problem..
Click Start > Programs > Accessories > System Tools > System Restore > pick a time previous to last update > Next > etc
Apr 08, 2010 | Acer Aspire 5630 Notebook
Monitor will not turn on
You can try doing a system restore! This will recover windows from an earlier time
Try to logged on in safe mode! Press F8 when your machine starts! Then choose safe mode!
Once you have logged in safe mode just do a system restore:
Click on Start, All Programs, Accessories, System Tools then select System Restore
Choose a date when your pc was running fine.. let the process to be done
Restart your machine normally!
Jan 18, 2010 | Acer Aspire One Netbook 8.9" Notebook
I did a system restore from the disks. Everything
you will need to reload the window NTLoader is not reading your masterboot record. reinstall windows again make sure the disk is clean .
Nov 17, 2009 | Acer Aspire 3100-1405 Notebook
Window vista is not booting the computer
Try starting in safe mode. If it does boot in safe mode then go to HELP, THEN SYSTEM RESTORE, pick a date before you had these problems. Good luck. You start in safe mode by pressing F8 then selecting SAFE MODE from the menu.
Jul 30, 2009 | Acer Aspire 3680 Laptop
Acer Aspire 3100-1405 Notebook Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
