Question about Minolta Di2510 All-In-One Laser Printer
Minolta di 2510 code c0500
Code c0500
  • 1 more comment
  • Anonymous Sep 22, 2008
    i cannot understand the wors is there anybody that can help me i have a minolta dialta 251 error code co500
  • Anonymous Mar 26, 2014
    C0500
  • Anonymous Mar 27, 2014
    dialta minolta copier (di 2510)
Lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Posted on Sep 02, 2008
Tengo problemas con mi fotocopiadora dialta 351 sale un codigo c0500 que hago?
Posted on Feb 09, 2009
Code C0500 problem
Posted on Sep 17, 2012
  • tkm_alexciit
    tkm_alexciit Jan 02, 2013
    como lo soluciono
    New Friend:
A multifuntion was decteted. please call you technical representative and provide de code below
C0500
Posted on Jun 22, 2011
How can I reset eror code CO 500 on konica minolta copier DI 2510
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Aug 08, 2016 | Konica Minolta Di2510 Di251 Di250 Di2010...
Minolta DI-151 trouble code c0500
Sir/Mam Power off the machine. Wait ten seconds then holding down the Stop/Cancel button power on the machine. Clear the code then power off the machine. Wait 10 seconds and power on. If the code comes back you need to look for a new fusing unit (Hot Part) DO not reset the fuser cold catch on fire. That would ruin a perfectly good day!:).
Jan 19, 2015 | Minolta Office Equipment & Supplies
How do i clear the user code on the minolta Di 2610
do you mean Di 2510 ???
Do you mean access code for adminstrator or the Password for accounts??
Mar 15, 2014 | Konica Minolta Office Equipment & Supplies
Di minolta 251 diplays the code c0500 if when the wires are connected properly and sufficient current is supplied. What do I do to correct it? Thanks.
Check Your Fusing unit. if there is any possible changes on it maybe wires wer cut off, or some pieces of paper left inside of it (fusing unit) blocking the thermostat or just simply buy an AVR.
Dec 08, 2012 | Konica Minolta Office Equipment & Supplies
IT AUTO CUTS POWER AND GIVES A CODE THAT IS C0500
i have a SF- 2510 sharp copier that is displaying the error code C0500. What does this code mean and how do I fix it?
Feb 23, 2011 | Konica Minolta DiALTA Di200 Copier
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Konica-Minolta DI-2510F Displays code C0500
Solution:
The C0500 code can be reset following the steps below:
1. Press the soft initialization on the right side of the control panel.{IT A SMAL HOLE THE SIZE OF PAPER CLIP IN DIAM-U CAN USE PAPER CLIP
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
GOOD LUCK
Dec 05, 2008 | Office Equipment & Supplies
C0500 Code in Dialta 3010
Clearing C5XX codes on Minolta Di2010/2510/3010/3510:
1. Push Warm Restart button (small button on right side of control panel. A small dot should appear on the left edge of the touchscreen.
2. Enter "3" on the keypad. This should get you the Initialize menu.
3. Select "Trouble Reset" at the bottom of this menu.
That should do it.
Jun 12, 2008 | Office Equipment & Supplies
Minolta Di 151
How to clear a C-0500 error code.SolutionHold down the [Clear/Stop] key while turning on the power.
For the Di151f, hold down the [0] key while turning on the power.
if the code comes back replace the fuser unit. DO not continue to reset the fuser can catch on fire and that will ruin a perfectly good day.
Oct 21, 2006 | Minolta Di151F All-In-One Laser Printer
Minolta Di2510 All-In-One Laser Printer Logo
4,262 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
