Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
One more time vinyl
All lights come on, the LED display also comes on, but it will not play.
thanks for any help you can provide.
  • Wurlitzer Expert
  • 211 Answers
What is it not doing? "Wont play" doesn't really give enough information. Is it in credit? Does the LED display show the selection you make? Does the carousel turn?
Posted on Nov 09, 2008
Which fuse is for the instrument panel back lighting?
Does the radio play ? Are any other back lighting components not lighting ? Does the HVAC control panel light up ? You probably need new radio !
The second interior lighting group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination, LED illumination and incandescent lamps.
When the ignition switch is turned to the RUN position, the radio VF display turns ON at maximum brightness. When the park lamps are ON, all incandescent and LED back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The panel dimmer switch potentiometer is an input to the body control module (BCM). When the driver selects a dimming setting by moving the I/P dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Jul 14, 2015 | 2008 GMC Sierra 1500
Nokia Asha 305 display light problem solution
With article and troubleshooting guide solution for Nokia Asha 305 display light problem solution Problem: No display lights, Dark display. Solution: Change LED, Change connector, Make jumper. phonetolls mobile repairing Nokia Asha 305 play light solution Article on this topic Thanks for checking out this Solution. contents provide include dozens of cell phone artical additional, pictures, with hardware and software troubleshooting guides for you. Support us like and connect with this blogger for latest newsletter please follow me. By Admin shahid abbas. Troubleshooting guide Open display back panel carefully and change lights red marking here in this. Remember one thing to do this job, please be ensure that light controller integrated stage is working well then change or check LED (light emitting diode) on display. There are 4 LED with series you can check faulty LED with check meter. At connection with meter probe LED lights show us. There on light emitting diode(LED) Regulated voltage are equal to battery voltage- 4.2. There are series of LEDs if missing one LED then All series is damaged. Warning! During working on this trick if accidentally your handset may have dead or faulted we are not responsible for that please read our privacy policy., ,
on Jun 24, 2015 | Cell Phones
Radio display light went out, radio and cd still play
If this is a late model vehicle, then is is very likely that your radio face plate is "LED" and not bulbs. If this is the case then you have to replace the radio. Sorry for the bad news.
Nov 16, 2013 | Vehicle Parts & Accessories
Hello i have a omt 1987 1015 lights power up but will not play when you select led shows record to be playing but does not play will not show credits or house hits have checked all fuses none blown have...
Is your 3 digit display on? If not, does the Z LED Flash when rotating the record carrier? If so, you may need to have your computer repaired. If the Z LED doesn't flash, check the 12 volt fuse in the amplifier. If you need your computer repaired or further assistance, please email me, Rod Stebelton,
Dec 27, 2009 | Wurlitzer Jukebox 1015 One More Time...
Turn on turntable the vinyl button doesnt wrk
This is a tough one. Sounds like physical damage. You'll need to take it to a service center for repair.
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 28, 2009 | Pioneer CDJ-800 Turntable
The display light doesn't come on to indicate what the unit is doing (frequency, mode, etc.)
I assume that it plays, you just can't see the display. It may just need a new display bulb, that back lights the display.
Feb 22, 2009 | Yamaha RX-V730 Receiver
Error on the vinyl mode will let me cue but not play
More than likely you have a bad switch, although this is not something that you could service yourself. I would suggest taking it to a service center in your area. Make sure they are Pioneer authorized, and know what a CDJ800 unit is!
DJ Equipment Repair Videos
DJ Equipment Repair
DJ Equipment Sales
Pioneer Parts
Jan 16, 2009 | Pioneer CDJ-800 Turntable
Wurlitzer one more time vinyl
How iwll it not play? Does the carousel rotate? Is there no sound? Does the red light flash? etc.
Jun 24, 2008 | Wurlitzer Jukebox 1015 One More Time...
Jukebox does have power but lights (except change box light) do not work nor does machine play. Although it is a 1015, it has not been converted to play C/D's. It still plays 45 rpm's.
The Wurlitzer One More Time comes in two types. CD or vinyl. No-one converts them.
What lights do you have on? Do the flourescent lights come on? Is there anything shown in the red LED display in the middle of the mechanism?
Is the machine in freeplay? If it isn't you need to put money in it.
Does the record carousel turn when you press the latch on the edge of the carousel? (It's at 5 oclock).
May 04, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
67 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
