Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool dishwasher du912fgbo
It will drain now but now it will not spray water
  • 1 more comment
  • woodmang50 Oct 07, 2008
    water comes into the machine and it well drain but when it goes to wash all i hear is a hum . the motor turns freely as well as the pump.
  • dsupple Oct 18, 2008
    I have the same problem with my Whirlpool dishwasher.   It fills with water and heats the water but it does not spray the water.  You just hear the hum like a timer.   It does drain the water at the end of the cycle.
  • Toby Norton
    Toby Norton May 11, 2010
    Your machine was listed under top load clothes washers (whirlpool ulitimate care II LSQ9564J) so I was sending you suggestions for a clothes washer. Now that I have a model number for your dishwasher, we can start going through for that. First of all, does your dishwasher fill? If it does, does it spray on the top arm, the bottom arm or neither? In the front right hand corner on the bottom, there is a peice of plastic. can you raise and lower this by hand. If so can you hear a click when you do so?
  • 246 Answers
Since I haven't heard back on this in over a week, I will assume it's been resolved with the clarification questions.
Posted on Jul 23, 2008
Why doesn't our Whirlpool dishwasher clean anymore?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 17, 2011 | Whirlpool Dishwashers
Hello, our Whirlpool dishwasher is about 3 years old. It is not cleaning the dishes; I don't think the arms are turning because the door is always dirty, so no water is getting that far. Also, the cycle...
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool Dishwashers
Hi, My whirlpool dish washer does not clean the dishes. Robin
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
The water used to completely drain out of the whirlpool dishwasher after the last rinse cycle. now water remains in the bottom. Also noticing decreased flow when actually draining into the garbage disposal...
Mar 09, 2010 | Whirlpool 24 in. ADG6340iX Built-in...
Whirlpool dishwasher doesn't clean very well
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Whirlpool Dishwashers
Water in bottom of dishwasher; seems to be spraying up during cycle; doesn't seem to be a pump if spraying up? what else could cause the water not to drain?
does it have a separate drain pump? when you look under it, is the drain line connected at front right corner of pump housing?there is a check housing in the tube that the drain hose connects to. it unscrews and has narrow opening on threaded end..may be blocked there.
Jun 12, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool ADG7540 integrated dishwasher - error code 6 flashes - can you tell me what this means please and is it repairable? thanks
my integrated whirlpool dishwasher is not spraying from the top but is letting water in from the bottom and draining okay
Apr 17, 2008 | Whirlpool Dishwashers
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
