Question about Equity Time USA Insta-Set 44200 Clock Radio
Manuals for equity clock radio 44200
I can't reset the time nor the month and date it didn't come with any manuals it just said to plug in and thats it
SOURCE: buttons not working.....
In the battery compartment is a small button marked "reset". Push this in after the batteries are installed and the buttons should work. You will have to reset everything.
Posted on Jun 26, 2008
SOURCE: timex clock radio T245S
Try this
http://www.timexaudio.com/pdf/T245_IB37357_46.pdf
Also if the screen is flashing "OFF" toggle the tab on the left
Posted on Dec 16, 2008
SOURCE: Equity 44100 clock radio problem
Hold the Alarm Set button down for about 5-7 seconds. The year will flash. Skip the year and date by pressing Alarm Set a couple times until the time is displayed. Use the Up and Down to change, then press Alarm Set one more time to save it. This clock is ****, by the way. I run into them in hotels and it makes me nuts as well. Very non-intuitive.
On the time lost issue...there is a button battery (CR2032) in a compartment underneath. That battery keeps the internal time so when the clock is plugged in, it "instantly" sets the time. Problem is, if the internal time is set wrong, then it instantly sets the wrong display time when it it plugged in. See procedure above to correct that.
Posted on Feb 26, 2009
  • 71 Answers
SOURCE: global atomic radio controlled clock
It should automatically reset to the correct time. Try taking the model number and Google for an answer. Hope this helps.
Posted on Mar 16, 2010
  • 5 Answers
SOURCE: reset cd clock radio? (manual missing)
Make sure the clock is in standby mode, as opposed to playback mode. Press time set button — the clock digits will blink. If they don't, you're in playback mode. Press the hour button to adjust the hour. Press the minute button to adjust the minute. Press time set button to confirm the time.
Posted on Feb 15, 2009
I have a insta - set clock radio model 44200 just open pkg noticed next to electrical cord hole there a small hole and there a 7 inch thin wire hanging out of hole is this extra wire they forgot to cut is...
That's the radio antenna. Just tuck it under the unit or along the back of the shelf or whatever if you get adequate reception. If you don't then you might try fussing with it--taping it up the wall, draping it over a book, that kind of stuff.
Oct 17, 2013 | Equity Time USA Audio Players & Recorders
Hi I have a insta set model 44200 clock radio just open pkg noticed next to electrical plug there a small hole with a 7 inch thin coated wire coming out of it what is this is it safe to use
Oct 17, 2013 | Equity Time USA Insta-Set 44200 Clock...
How do I switch Equity 44200 from Celius to Farenheit?
Hold the Alarm 2 button down to change from Celsius to Fahrenheit.
Jan 19, 2012 | Equity Time USA Insta-Set 44200 Clock...
Need to know how to set time on ISTA SET 40009
Instructions
    • 1 Press and hold the "Alarm Set" button for five to seven seconds if you have an Insta-Set 40001, 44100 or 44200 model; the year will begin to blink when the clock is ready for adjustment. If you have an Insta-Set 40009 or 40018, hold the "DST" button for five to seven seconds (until the hour begins to blink).
    • 2 Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock.
    • 3 Set the month, day, hour and minute. Press the "Alarm Set" or "DST" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
    • 4 Press the "Alarm Set" or "DST" button after setting the date and time to store the information into your clock's memory.
Read more: How to Change the Time on an Equity Insta-Set Clock ' eHow.com http://www.ehow.com/how_5657092_change-time-equity-insta_set-clock.html#ixzz1d1qIibS4
Nov 07, 2011 | Equity Time USA Insta-Set 40009 clock
This clock is an automatic set clock and it is 15 minutes ahead in each timezone and is not able to be reset by us
Press and hold the "Alarm Set" button for five to seven seconds and the year will begin to blink when the clock is ready for adjustment. .
Press alarm 2 to change from Celsius to Fahrenheit.
Press alarm 1 to change from 24 hr time to 12 hr time.
Aug 08, 2011 | Equity Time USA Insta-Set 44200 Clock...
I have a clock that will not get correct time. I have no way yo set it . Model #44100 Equity.
All Equity Insta-Set clocks automatically set the correct time and date when you turn on the power. Occasionally, the automatic time-setting feature malfunctions and you must reset the time yourself. Manually changing the time to the correct time on an Equity Insta-Set clock requires the push of only a few buttons to get the clock back on track:
1. Press and hold the "Alarm Set" button for five to seven seconds, the year will begin to blink when the clock is ready for adjustment.
2. Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock
3. Set the month, day, hour and minute. Press the "Alarm Set" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
4. Press the "Alarm Set" button after setting the date and time to store the information into your clock's memory.
Best regards,
gylacz
Mar 18, 2011 | Audio Players & Recorders
Need to reset the time display on a equitytime model 40009
This solution from the answers below worked on my model 40007 clock today: If you hold down the button on top that says DST for like 10 seconds it will allow you to force change the time.
Thanks. wd 11/21/2010
Mar 15, 2010 | Equity Time USA Insta-Set 44200 Clock...
How do i change from military time on a insta-set alarm model 40009?
This may or may not work. The 40009 and 40010 are almost identical. The 40009 doesn't mention military time and the 40010 does, so you might want to what the manual says. 40010 manual and 40009 manual. According the 40010 manual, is says:
Displaying the12/24 hour, Date, Month and Year:
Display the 12/24 hour by hold the "+" button for 2 seconds. To display the date, month and year by press the "-" button, the year appears and then if pressed again, the month and date (eg. “12 31” means Dec 31) appears.
So maybe that will do. I have a 40010, but my manual is different from the one on the website. Its DST button and not Alarm Set button to change the time. So maybe try holding down different buttons for a couple of second see if one lets you change it between 12 and 24 hour. Good luck, hope this helps.
Mar 16, 2009 | Equity Time USA Insta-Set 44200 Clock...
Equity Time USA Insta-Set 44200 Clock Radio Logo
517 people viewed this question
Top Equity Time USA Audio Players & Recorders Experts
handy2011
Level 1 Expert
Tom Chichester
Are you an Equity Time USA Audio Player and Recorder Expert? Answer questions, earn points and help others
