LG 42LB1DRA 42 in. LCD Television Logo
Posted on Nov 28, 2010
Push power button on remote tv powers up white in upper L corner, black in rest of screen no other functions with remote
kmkrreeves1
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Nov 28, 2010
kmkrreeves1
Contributor
Level 1:
New Friend:
Answers
17
Questions
Helped
4543
Points
40
Call manufacturer phone number in papers that came with it
VIZO E70 - E 3 Wont turn on
Hi Bob, you've going to need to get the back off and get some voltage readings, start with the power supply, go by the legend on the board, let me know what you find, and I'll give you some advice on what to test next
LG plasma 50PK550 remote will not turn TV off and ON. unplug and plug power cord in it turns on showes chanel 3 left upper corner & volumn minimum left lower corner then turns to white screen .
You should have manual buttons on the tv itself to control input and volume. It appears it is defaulting to antenna channel 3 and low volume when first powered on. You can buy universal remotes to control your set.
Philips 52pfl5704 no screen image
Sounds like main board fault. Contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney ([email protected])
2helpful
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
There is shadows on the insdide of the screen
Turn your TV on by pushing either the power button on the front of the TV or the power button on the remote control, which is located in the upper right corner of the remote.
Step 2
Press and hold the "up arrow" button on the remote control. The up arrow button is located in the middle of the remote, to the left of the "Input" button and below the "Picture" button.
Step 3
Press the power button on the TV while still holding down the up arrow button. The TV will turn off and then turn itself back on.
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV to its factory settings.
Hope this helpout.......
2answers
LG TV - TV Guide Function Stuck
check the buttons on the remote and see if they are stuck or on the tv it self
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
17helpful
3answers
Closed caption
Closed caption wont turn off was solved by Bresnan tech. He told me the only way was to push the power button on my remote & then push the menu button right away & it would bring up a white screen & cc would be on it. I could't get it to work so I pushed the power button on my remote & the menu button on my motorola cable box & up came the screen & closed caption was on it. I disabled it & it took off the closed caption. Hope this helps
Sony KP-48S65 48 in. Rear Projection: fine tune convergence
you will have to go in the service mode. be careful as you could damage the tv if wrong settings are changed. with the tv off push on the remote display 5 vol+ power. now hit the 1 button until you see pje fdis on the upper left. now push the 9 button to enter convergence. you should now have a cursor on the screen. usr the 3 button to switch colors. use the directional pad on remote to move the cursor and the enter button in the center of dir pad to select or deselct a point in the screen. push muting and then enter to save convergence. now restart the tv and all done
6helpful
2answers
TV Problems
If you hold down the display button, you will lock the tv. Hit the power button and you will prevent anyone from wathing the tv without the remote. The only way to unlock it is by turning the power on with the remote of course (the blue screen should show) and hold down the display button.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
