Question about Cell Phones
Razr v3 and LG HBM 770
My phone can detect the device but when I try to select it I get "cannot connect" and the 770 is in pairing mode
  • 1 more comment
  • razz001 Jun 24, 2008
    I am connecting via bluetooth. I go to settings, connection and I turned bluetooth option to on. In the same menu I select "add audio device". I then do the scan and the scanning results list the LG HBM-770. I then click select and it does the seeking. it either times out or it give the "Unable to Connect" I am trying to get the razr v3 phone to add the HBM770 as a device in my bluetooth device list.
    It never prompts for a passkey
  • razz001 Jul 19, 2008
    Solution was to have the phone replaced. Software update did nothing, the new phone paired just fine with the LG HBM770
  • 2,071 Answers
Try to clean the usb port ,brush it using old tooth brush,with the use of a ligther fuid or an alcohol ,brush each port,,try to checked usb cable is ok not cut,,If nothing happens ,try to reset your cellphone,go to menu set for factory default...
Posted on Jun 24, 2008
  • Cell Phones Master
  • 13,433 Answers
Did you enter a passkey for the headset, a default one may be 0000
    Genius:
  • 1,142 Answers
How actually you are connecting the device elaborate it please
  • Maanita Chadha
    Maanita Chadha Jun 24, 2008
    Update the firmwar it will resolve your problem
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Cannot place LG-HBM-710 in discoverable mode
It sounds as if the device is not paired with your Chocolate. Press and hold the button on the face of the HBM-710 headset for approximately five seconds, or until the light comes on and stays on steadily, then discover the device with your handset's Bluetooth screen. Once it shows up in the list of devices, select in and pair it with your phone.
Jul 07, 2009 | LG HBM-710 Wireless Headset
My voice is garbled and the people I call using a LG HBM-770 bluetooth wireless headset can not understand me. Suggestions??
tried pairing with a different phone and turned up the volume button...don't know which change made it work but it worked fine. So I'm guessing it might have been the voume was not set correcttly.
May 27, 2009 | LG HBM 730 Bluetooth Headset Wireless...
HOW DO I PLACE AN LG BLUETOOTH HBM710 IN "DISCOVERY MODE" ?
Just came across your question while searching for the same answer - Here's what I found out:
When it's off, press and hold the on button for 5 seconds - it'll turn on, but keep holding until you hear the short beep - the light's on and you're where you want to be. Here's the full text that I found from the manual:
-With the HBM-710 off, press and hold the PWR/END button for 5 seconds
(You will hear a short beep and the LED indicator will stay red, when the device enters pairing mode)
-Using your handset, find the "Bluetooth menu" and "search for" or "add" new devices
- Select "LG HBM-710" from the list of devices and pair it with your headset
- When asked for the Pass/PIN code during the pairing procedure, please enter "0000" (4 zeros)
- Once pairing has been completed successfully, you will hear a beep
- After pairing successfully, be sure to "connect" to the LF HBM-710
- If you want to pair with other devices in the future, the headset must be in "Pairing mode"
- If it will be not connected the "Pairing" for three minutes, it will be turned off.
Apr 03, 2009 | LG HBM-710 Wireless Headset
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
IT is actually a problem with the phones Bluetooth acessory
The passcode for your Prada HBM-510 bluetooth headset is '0000'
Feb 09, 2008 | LG Prada KE850 Cellular Phone
Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Feb 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Passkey
The passkey is 0000
Dec 25, 2007 | LG HBM-550 Wireless Headset
To connect N95 with bleutooth headset LG HBM-550
1st switch on bluetooth for both devices!
2nd go to your bluetooth menu in your phone
3rd click on pair devices
make sure that your phone is visible to other bluetooth device
4th select the device and click on pair devices!
its done!
Dec 08, 2007 | Nokia N95 Cellular Phone
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
