Question about Amana Washing Machines
No hot water to washer - Amana Washing Machines
  • 958 Answers
Check if there is hot water supply in your house. check if the wash and rinse mode selector is set to either warm or hot. check if there is dirt or clogged in the hot water supply filter located in the hot water input solenoid. if everything is ok, check the resistance of the hot water solenoid valve, if there is no reading, replace the solenoid valve. if there is, check if there is voltage present while operating. i hope i was able to help.
Posted on Jun 24, 2008
What does "EFO" stand for? It keeps blinking on my washer
EF0
displays due to washer over-sudsing or due to washer not filling with
Hot
water.
Causes for washer over-sudsing
Not using High Efficiency (HE) detergent.
Too much detergent was added.
Using too much 2X or 3X HE detergent
Solutions for over-sudsing
Always use HE detergent in an HE washer. It is formulated to be a low-sudsing detergent and made especially for HE washers.
Be sure to use the correct amount of detergent. HE washers require only a small amount of detergent.
Note
: This amount may need to be adjusted for water hardness, load size, and soil level.
If using a 2X or 3X concentrated HE detergent, much less detergent is needed. If suds are seen, reduce the amount used.
If using a water softener, less detergent.
Solutions for Hot water not entering the machine are
Make sure both Hot to Cold water hoses are connected properly at the faucets and at the washer.
Fill hoses are usually color coded, blue for cold and red for hot.
Verify that the hot water inlet hose is connected to the hot water faucet.
Verify that the cold water inlet hose is connected to the cold water faucet.
Verify that the hot water inlet hose is connected to the back of the washer into the hot water inlet port.
The inlet port is usually labeled with (H) or (HOT).
Verify that the cold water inlet hose is connected to the back of the washer into the cold water inlet port. This inlet port is usually labeled with (C) or(COLD).
hope this was some help,all the best.
Dec 16, 2016 | Washing Machines
My kenmore serie 300 washer only wash with cold wather no hot wather
If I understand, you are saying that you are not getting any hot water coming into the washer. First, I would make sure that you have hot water available at the washer spigots. SLOWLY unscrew the hot water hose at the hot water spigot and see if you have hot water available. If you do, the problem is usually at the water inlet solenoids, or if you are lucky, the water screen filter. Turn off the how water spigot and unscrew the hose at the washer. There is a screen there at the washer water inlet, see if it is clogged. If not, the problem is most likely the solenoids. To replace the solenoid unit requires some disassembly of the washer.
May 18, 2016 | Kenmore Washing Machines
Washer flashes F8 E1. What is this
hook up hot hose and turn on the hot water and dont use hot water control it will not use no hot water ,but washer need to see the water pressure ,but will not use no hot unless you ask for it Sonny
May 29, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Hot water does not fill in the washer. The spicket has hot water.
There is an obstruction after the shut off to the hot water hose that feeds the washer. Shut off the hot water, disconnect the hot water hose from the washer, and hold the end in the washer tub. Open the hot water shut off. If now water comes out the problem is in the hose. Replace or clear obstruction. Make sure washer at hose end is in place before reconnecting to washer.
If how water flows, inspect the input hose connection to the washer. Some have a screen filter that my be clogged with sediment or other debris. Clean and try again.
If still no hot water, there is likely a problem with the hot water solenoid valve inside the washer itself. You'll have to remove and probably replace the valve or coil (or assembly).
Mar 09, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Hot/cold cycle works but w/out hot water
I got my washer from a friend and his did the same thing. I have to put the washer on normal for cold water and heavy load for hot water.
Apr 15, 2009 | Hotpoint VBXR1090B Top Load Washer
What does efo mean
Electrolux Washer Fault Code for EFO or EF0
Drain Filter is Clogged. Resolution => Click lint filter for soap buildup or other debris. Check drain hose.
Oversudsing - A high efficiency detergent was not used.
Too much detergent was added. Resolution => Use only a high efficiency detergent. Follow manufacturer's recommendation for dosage. Amount may need to be adjusted for water temperature,
water hardness, load size and soil level.
Hot water doesn't enter washer - Hot water hose is connected to the wrong faucet. Hot water faucet is not turned on. Resolution => Connect hot water hose to hot water faucet and hot inlet on
washer. Be sure hot water faucet is fully opened. Check water heater.
Jan 03, 2009 | Crosley CW5000 Front Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Dec 27, 2007 | Kenmore Elite 45986 Front Load Washer
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
67 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Mike
Gerry Harvey
Gerry Harvey
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
