Question about Canon Office Equipment & Supplies
Blocked print nozzle on the cyan cartridge have tried deep cleaning several times but no success
  • john750 Jun 25, 2008
    i replaced the printhead and aligned it appx 2 weeks ago
  • Anonymous Feb 03, 2009
    Cyne
    Megenda
    Yellow are ok work
    By Black INK in not come to below of the head
    plz give reply
  • 197 Answers
I'd say that your printer head needs to be replaced.
Posted on Jun 24, 2008
Wont print blue
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked cyan print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Oct 17, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
My HP Deskjet F4488 printer's cartridge is not working . It slides only
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Sep 15, 2012 | HP DeskJet Office Equipment & Supplies
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Canon PIXMA iP3000. I have completed a nozzle check, but have odd results... BLACK-Perfect CYAN-4 EQUALLY SPACED WHITE LINES...NO DROP OUTS PALE CYAN-PERFECT MAGENTA- 4 EQUALLY SPACED WHITE LINES...NO DROP...
Inkjet printers do not like being left unused for long periods.
Some of the color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 17, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Inkhead clogged. Have tried deep cleaning several times. Cyan just won't print even though it is a new cartridge
Inkjet printers do not like being left unused.
The print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
Nov 14, 2010 | Lexmark Prospect Pro205 Wireless...
Will not print cyan
The cyan print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked cyan print nozzles. Also check the cyan cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced. NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Canon I960 InkJet Photo Printer
Hello my 7590 printer will not print in cyan
The chances are you have a defective cyan ink cartridge. If you are using an aftermarket/reloaded cartridge and the cartridge chip is defective. First try a new cartridge. The best bet is a new OEM cartridge, run the deep cleaning utility 3 times. The nozzle may be clogged and this will clean the nozzle.
Aftermarket/reloaded cartridges ink do not always meet the specifications for the printers that use the finer inks.
Let me know if this works for you. Thanks.
Mar 07, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Won't print(after changing cartridges
blank pages and bad print are not the same problem. Regarding costly ink, a epson printer tech told me once that the secrete to cleaning a bad print head was to run deep clean 7 times in a row and then a head test and it has worked for me several times on other printers (not an expert here, just personal experience).
Additional note, I have seen both cleaning chemicals and cleaning cartridges on the web, example, searching google for one for my printer I would search for cc-bci-6c which is for a canon cyan cleaning cartridge. Don't know if they work but in case it helps.. good luck.
Barry,
Mar 02, 2008 | Epson Stylus CX5400 All-In-One InkJet...
55 people viewed this question
old marine
old marine
