Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D
Chest Freezer doesn't get cold
I checked the compressor and it is running but isn't cold at all. Checked the R132 and the level is fine. Is the compressor Bad? I was thinking it may be running but not compressing. Worked fine when unplugged and when put back into service about a month later started this.
  • Rinky Dink Jun 30, 2008
    Yes the unit had been moved by "professional" movers. How do I know if the compressor is working correctly. As I said, it is running. I checked the pressure and it is not low on freon. So I hace to assume the compressor is running but not compressing?
  • 161 Answers
Was this unit placed on its side or back? This can cause oil to get where it shouldn't and block freon flow. If the unit has not been moved this is not an issue. Could be the compressor but sounds more like low freon level. Most leaks happen when units are turned off for long periods. I don't ever believe in charging a deep freeze unless you can positively say you have found and fixed the leak. You can never really trust it again and the food inside is usually worth more than the freezer.
Posted on Jun 30, 2008
Won't get cold
There are many reasons why is not working. 1.if the compressor is not running, Relay or overload burn, they are attached to the side of the compressor 2, thermostat may not be working. 3. if all of the part i mentioned are working fine your compressor may need to be replace.4 if the compressor runs but still don't get cool, there is a internal gas leak inside the freezer. The only way to find out theses issues, is by having the necessary tools and experience.
Nov 15, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
My ignis chest freezer isn't freezing anymore even
your cooling system matchine facced this problem.
Mar 20, 2013 | Freezers
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
I have deep freezer chest that does not freeze but when you plug it in you can hear it click on but will not get cold at all has been unplugged for a few years but stored in a dry building
If it doesn't get cold at all, then your compressor is not running. Which could be the start relay or start capacitor or even the compressor. The relay and capacitor are not that expensive and pretty easy to replace, but if it is the compressor then you might not want to put that much money into an older unit.
Aug 13, 2011 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Compressor runs but freezer not getting cold
Have the gas checked. If the thermostat pick-up is frozen over that could result in the contents of the freezer not getting cold, but for that there would have to be a build up of ice on the sides of the freezer.
Jan 25, 2011 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Used chest freezer not cooling
chest freezer operation is among the simplest available. if the compressor is running and its not cooling there are only 2 possibilities. low or no refrigerant and or a bad compressor. so if you have the ability to return the unit I would. could luck peyton
Feb 01, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Maytag chest freezer mac1557aew does not get cold
This can be a number of things, one being a bad compressor/motor.
Does it run at all?
If not, the compressor needs to be looked at.
If you are handy, there may be a wiring schematic in the back to further troubleshoot.
You can trace the wiring from the thermostat to see if there is power at other components.
Feb 20, 2008 | Maytag 14.8 cu. ft. / 419 liter Chest...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
Sep 12, 2007 | Freezers
Open Questions:
See all Frigidaire 13.7 cu. ft. / 388 liter Upright Questions
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D Logo
198 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
