Question about Brother LS-2125 Mechanical Sewing Machine
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just sits against the material...please help.
  • 33 Answers
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Posted on Sep 05, 2008
Model LS-2125i..How do I access the bobbin
Make sure that the needle is fully up first and raise the presser foot. To access the bobbin, you need to remove the flat bed attachment that is at the front of the machine. This just rotates up and off the machine. Next rotate the shuttle cover down from the top of the cover. Now you can pull out the bobbin case towards you by the latch. This piece goes across the center of the bobbin case and to the right. Now you can remove an empty bobbin (if needed) and put the wound bobbin into the bobbin case to replace the bobbin.
For this procedure, the pictures in the manual may be clearer than the written description. See pages 14 and 15 (16 and 17 for the PDF) in the manual. Brother currently has the manual here: http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_LS_2125i_EN_1628.PDF . The LS-2125i support is here: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=LS2125i . Click on the Manuals & Documents page. Most Brother manuals and other documents can be found by searching here: http://www.brother-usa.com/Support/ .
I hope this helps.
Oct 28, 2016 | Brother Ls-2125i 10-stitch Portable Free...
Presser foot wont connect
It is most likely the presser foot you are trying to install was not made for your machine. There are so many machines available and most of those machines have their own presser feet, which are not interchangeable. Unfortunately, even a Singer presser foot is not interchangeable with other Singers. Some have screw attachments, others have lever attachments, some have long shanks, others have short, some are straight, others are slanted. You need to figure out what style presser foot your machine takes and then search for either the presser feet that fit or a shank adapter that you can then use snap-on feet (kits are available on eBay).
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
Sewing Machine Feet eBay
Jul 17, 2016 | Sewing Machines
How do I PUT together the presser foot. the part that snaps into foot
Here's a manual you can download. It should have instructions for attaching your presser foot:
Instruction Manual White 955
If you are using snap-on feet, be sure that you have the low-shank snap-on adapter for your machine (looks something like these) that actually clamps onto the presser foot:
Snap on Shank Low Shank
Aug 09, 2015 | White Sewing 955 Mechanical Sewing Machine
My machine is a Husqvarna Prism 980, and I'd like to know if it's a high shank or low shank.
Take a Measure
With the presser foot in the down position, measure from the Needle plate of the machine to the center of the thumb screw of the ankle of the machine (the part that the presser foot snaps on to).
Low Shank - measures ½"
High Shank - measures 1"
Most consumer machines are low shank. There is probably not a walking foot that is made for this machine but there may be some third party suppliers that have a walking foot that will work. Stitchery Sewing Machine Attachments Needle and Thread
Apr 10, 2015 | Husqvarna Sewing Machines
Thread is caught inside a Brother LS-2125i
Lift foot. Remove two screws attaching metal plate to machine. Put screws on the sticky side a a piece of tape for temporary storage. Remove knot built by sewing without material in machine or extremely loose upper tension.
:o)
Jun 03, 2011 | Brother Sewing Machines
How to attach a quilt guide
You have to unscrew the screw for the presser foot first. The walking foot will then fit. Use the same screw to attach the walking foot. Before you insert the screw, take the white handle on the walking foot and slide it on the screw arm for the needle. Now tighten the screw.
Mar 21, 2010 | Singer Sewing Machines
Appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
My presser foot won't snap on to my White 3032
It sounds as though you are missing the ankle which is the part the foot attaches to. The ankle attaches to the metal rod with a screw and the foot snaps onto the ankle.
sewman7
Apr 30, 2009 | White Sewing White 3032
I have a Brother LS 15 sewing machine
raise presser foot to highest level pulling wheel toward you(counterclockwise) release the foot assembly with the lever at the back of the foot holder assembly place you quilting foot in line with the slot on the shank lower the presser foot lever on the shank if it is where it should be the bar will snap in and you should hear an audiable click or snap let me know if this helps
thanks amy
May 12, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
453 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
