Question about Canon LIDE20 Flatbed Scanner
Unable to select TWAIN source
Please help, my canon lide 20 flatbed scanner has recently started coming up with this error message: Unable to select TWAIN source
I have been using CanoScan4 for quite some time without any problems and this came unexpected (as most problems do).
I have since tried connecting it to various USB ports on my computer to no avail.
Any assistance will be appreciated!
  • oldanst Nov 26, 2008
    canoscan 3200f
Tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an alternative..here we go..
on vista 64 os/vista any version..click Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Posted on Oct 13, 2009
    Scholar:
  • 111 Answers
I had the same problem. I just wanted my Canoscan LiDE 90 to scan in PDF format. Toolbox kept insisting it was unalbe to select the twain thing. So added it my path, reinstalled, etc etc.
Then downloaded MP Navigator EX. Presto ! It's basically the same thing as Toolbox. Found it at:
http://www.canon.ca/inetCA/serviceDetail?m=load&id=4&sid=26&mid=0002200344&type=S
Posted on Sep 13, 2011
Unable open twain source please
This is an issue with the Driver Installation, Get the drivers Uninstall and reinstalled from the CD.
May 11, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
When i try to scan i get this message: unable to open TWAIN source Please check connection then re-start Toolbox the connections are tight
Driver mismatch - the driver of the scanner has forgotten the location of the TWAIN driver because another software has been using it lately. Follow this
http://weblogs.asp.net/jeffwids/archive/2009/11/02/canon-scanner-unable-to-open-twain-source.aspx
Feb 20, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
When i am going to scan at that time in the screen select the twin source. what is the twin source of canon canoscanlide25
The prompt is probably asking you for the TWAIN source to use. In that box, simply select the Canon TWAIN source. If one isn't present, install the TWAIN drivers for this scanner.
Hope that helps,
MyEfact
Jan 04, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
Hi there, I have a Canon Flatbed scanner (Lide 25) and when i try to scan i get an error message as follows: 'Unable to load TWAIN server'. How can i fix this?
Hi Jason
A Simple fix just reinstall your software that came with the scanner and this should re establish the link between twain and your scanner
Regards Alan (alstech)
Please dont for get to leave feedback if this was helfull
May 12, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan LiDE 20
already install the scanner driver but still can't working properly.
Sep 04, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Aug 04, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Your post for CanoScan LiDE 25
Hi there, yes I did everything per your instructions, Toolbox is installed and it still says, "release the lock switch, detach I/F cable and reconnect. Scanner driver will be closed" and then after clicking on that it says "Unable to open TWAIN source. Please check connection then restart toolbox" I have been to the Canon site and downloaded driver sites and it says everything is working. but when I go to scan it comes up with the boxes I said before. Quite lost at the moment? Thanks Maureen. PS I have unstalled and reinstalled
May 22, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon scanner
TWAIN is the type of scanner driver that is used for this scanner. It is probably the most common type of scanning driver.
Did you install Toolbox? Not sure? Assuming this is Windows, click Start, All Programs, Canon. Look for open CanoScan Toolbox (4.9 I think). Once this is open, click the 'Settings' button. There should be a drop-down menu for 'Select Scanner'. Make sure this shows the CanoScan LiDE 25. If that scanner is not listed, then the scanner driver is not being seen or may not be installed.
Once it has been verified that the LiDE 25 is selected, click OK. Next, click the 'Save' button. Check the box for 'Display the Scanner Driver'. Now click the 'Scan' button at the bottom.
The next window that pops up should be ScanGear. If this happens, then everything is installed and the scanner is being detected properly. Attempt to scan or preview.
If there was a particular application you were trying to use and you are still having issues with it, please give those details.
May 19, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon LIDE20 Flatbed Scanner Logo
14,263 people viewed this question
old marine
old marine
