Question about Sansui COM3101 13" TV/VCR
Hd box does this tv need an hd adaptable box, because i got the govt coupon, but I see an "HD" on the video part of it. Is this box necessary or is this tv already OK for switch to HD?
  • 4,234 Answers
First of all I don't believe that this is an HD set. The coupon is for a converter that will allow an analog TV to receive digital broadcasted signals over the air. If this TV is connected to either cable or satelite, the converter box is not needed.
Dan
Posted on Jun 24, 2008
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
I need to know what cables to get to make it true HD. Also I wanted to know why I can't receive local channels.
go to menu then tuning,set from cable to air,for local channel.you can't get true HD for cable because cable is an analog signal
Sep 07, 2010 | Televison & Video
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
My 53UDX10BA is HDTV-ready. Where can I get the
Your TV accepts HD inputs from HD cable boxes, video game systems, Bluray players etc. There is no adaptor needed just connect the HD device to the component inputs on the back of the TV which are GREEN/BLUE/RED in color. Please take a moment to rate my answer. Thanks..
Nov 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My area went to hd tv and now i can't listen to the tv stations
You can purchase a converter box that will allow you to pick up the digital broadcasts.
This should only apply to you if you were getting your tv shows over the air with an outside antenna.
If you do need the converter box, you have until July 31 09 to apply for a $40.00 coupon that you can use to help offset the cost of the new converter box.
You can apply for the coupon at this website https://www.dtv2009.gov/ which also has a lot more information related to the digital conversion.
Jul 18, 2009 | Sony ICF-S79V AM/FM/Weather/TV Radio
Connection for y pb pr cables
The color-coding used for the RCA connectors is nearly universal:
  • composite video - yellow
  • audio - red (right channel) and white (left channel)
  • component video - green (Y), blue (Pb) and red (Pr)
Also, these jacks are normally labeled in print as well, although it's sometimes hard to read the text on some equipment.
Match the connectors on your converter box to the corresponding connectors on the TV. If your converter box was one purchased with the $40 US Government coupon, it may not have the component video outputs. The only coupon-eligible boxes are the most basic models, and they sometimes have only RF (channel 3 or 4) and composite video outputs available.
May 03, 2009 | iLO 3200 32 in. LCD Television
I have HCL5515W tv. Want to convert to HD tv.
Not without the box, HDTV didnt really made an appearance except in the past 5 years
Jan 18, 2009 | Samsung HCL5515W 55" Rear Projection...
Dell W3000lcd tv
The tv only has a NTSC (analog) tuner built in. So if you don't subscribe to a cable or satelite company and you get your broadcast from an antenna at your house, you will need a converter box.
Dec 29, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Adding HD to projection 43" TV
You will need to connect an ATSC tuner box to your TV. You can find a lot more information about the switch (and even some government coupons for the boxes!!) here:
Feb 17, 2008 | Televison & Video
Sansui COM3101 13" TV/VCR Logo
91 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
