Question about DeLonghi Heating & Cooling
I have a model DE500P Dehumidifier and it is blinking "E1, E2 on the display.
I have not fixed it yet, but I believe that I can. I was told by Delonghi that two of the sensors are bad. The fix is going to cost me enough, & I don't want to pay any more to fix the dehumidifier than I need to. Thank you any way, It is good to know that help is out there if and when needed.
Sincerely.
Rick Bitterman
Posted on Jun 25, 2008
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
I have a De Longhi de500p. Runs and I can hear the compressor kicking on and run. But I am not getting any water in the tank. Room temp 75 degree and humid meter set at 40 .Please give me some advice
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 31, 2011 | DeLonghi DE500P Dehumidifier
It stopped working. One display reads "CH" and
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Mar 26, 2011 | Comfort-Aire BHD-501 Dehumidifier
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Jan 09, 2011 | Haier DE45EAL Dehumidifier
Need instruction booklet
You can get the manual of the one that you have listed under on the link below. If it is not the right one please give us the make and model # so we may get you the right one.
http://www.sylvane.com/images/productpages/DeLonghi/Dehumidifiers/de400-de500-de400p-de500p.pdf
Good Luck and please rate 4 thumbs for the free answer
May 06, 2010 | DeLonghi DE500P Dehumidifier
It is flashing E1 and is running with no water in bucket
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 04, 2010 | DeLonghi DE500P Dehumidifier
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
What does P1 mean on display?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 16, 2009 | Danby Dehumidifiers
De500p lost owners book
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
This should solve your problem.
May 05, 2008 | DeLonghi DE500P Dehumidifier
Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Aug 02, 2006 | Danby DDR583R Dehumidifier
Heating & Cooling Logo
258 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
