Question about Frigidaire Refrigerators
Top mount p/n 241857200
Should i remove the foam from the cold control?frige is not working rite
3 Suggested Answers
  • 210 Answers
SOURCE: i have a lg top freezer, model GR-s462GC
the problem is most likely a thermal fuse, located in the freezer on the evaporator, has blown. The lights on are indicating an error code. If you unplug the unit and then replug it, it will run until it hits the defrost cycle. This will at least keep your food cold until you can get service.
Sgt 48
Posted on Jun 01, 2008
  • 20 Answers
SOURCE: New frigidaire top mount freezer gets partial
if you put your hand up there over the vent can you feel cold air? That is your damper control. You should be able to feel cold air.
Posted on Aug 20, 2009
Water slow ice not thick
if you have a side by side frige thin wen you open the door on your frige side thare shud be two diles one for the freezer and one for the other thurn the one that has freezer two the rite intell it gets on 5 or wen it gets to max and if its a reguler frige then and it a new one then its in the freezer part if its a older one thin there both in the bottom frige an torwds the roof of the inside if that dont work have your filter cleaned and ask a frigeration company geve you a shot of freeon in it
Dec 16, 2009 | Dishwashers
Model TBX18KMB. Liquids on top shelf often freeze. Also,need to cut electric bills,can Power Saver help?
Turn the refrigerator temp control down try factory setting, usually c on frige and 3 on freezer control. The cold air circulating from the freezer enters at the top of the frige therefor it is usually colder.
Nov 04, 2009 | GE Refrigerators
Fridgedaire freezer not staying cold. I can
did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Jul 25, 2009 | Frigidaire FRT17B3A Top Freezer...
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer is freezing but fridge is not cold as it was
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Feb 07, 2009 | Frigidaire FRT15G4B Top Freezer...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
64 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
