Tryed removing the CMos Batt and everything cant boot the comp without a password, I need to clear it
If you are getting password in the booting of the pc then it is bios password plz check the link
http://www.tech-faq.com/reset-bios-password.shtml
if it is not then try to boot in the safe mode and change the password
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
When
you boot up to the log in screen type in administrator as user to log
in if you cant log in
during
the boot up process you will see on the screen for a short amount of time press
a certain key to enter set up press and
hold that key during the boot up process to enter BIOS scroll down to set user
password or supervisor password you can change or remove your password from
there
also
The
most common way that we know on how to reset or clear the BIOS password is to
physically remove the power from the computer by disconnecting the power plug
and then removing the Cmos battery for 30 minutes from the motherboard. Another
way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2
methods mentioned works because most motherboards use a battery to sustain the
BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the
battery power, the BIOS/CMOS settings will be erased. Hope this helps
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
hope this helps dont forget to vote!
