Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby vacuum how to you tighten the belt?
    Problem Solver:
  • 4 Answers
With the kirby belts take the rug nozzle off take off the brushroll take off the old belt and turn it inside out then reinstall it
Posted on Jul 10, 2008
    President:
  • 1,673 Answers
Take the nozzle of, remove the brush roll, put the new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Posted on Jun 29, 2008
4 Suggested Answers
Arius
  • 446 Answers
SOURCE: how do you install the belt on the kirby vacuum
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Posted on Nov 27, 2008
  • 10 Answers
SOURCE: How to put a Kirby Vacuum belt back on
To put on a kirby belt all you need to do is put on the belt on the brushroll, put the brushroll into the housing making sure the marks on the end of the brushroll are the same. Take the spin dial in the front and "hook" the belt till the dial reads off. Put the head back on the machine and spin the dial to "on".
Posted on Jan 27, 2010
VacuumRepair
  • 438 Answers
SOURCE: i need to know how to put my belt back on my kirby
Greetings from GoVacuum,
Here's a very informative video that we've recorded explaining in detail how to correctly install the belt on your Kirby Generation vacuum cleaner. I hope this will help you.
Kirby Belt Change Video;
If this video was helpful, please be sure to rate this Solution by clicking on the 4 Thumbs Up icons in the top right hand corner of the page. If you have any questions, please feel free to email me, I'm more then happy to answer any questions you may have.
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
My kirby heritege the bar is not spining the belt is fine
Remove the clamps from the suction nozzle and pull out the roller. First of all check that both ball bearings are in order, so dust and hair free and run easily without too much play. Look carefully at the different depth marks on both sides and Make sure that they are reverted to the same setting marker.The belt is in the middle and with the square gray dial in front of the suction nozzle, you fully tighten the string so that the red color face of the top is visible when you look through the hole of the suction nozzle you see that the belt is tightened and in this Position may leave the belt for a short period of time, as always as soon as possible, ensure that the tension of the belt is off after each use.In short, in the tightened position, place the suction nozzle on the mounting bell at the bottom by lifting the motor housing slightly at the front or adjusting the depth adjustment as much as possible, just what you want, first place the suction nozzle on it and fix it with the clamp and then Couterclockwise turn the gray knob into the green mode.
Kirby Heritage II and Legend Vacuum Owner Video
Apr 12, 2017 | Kirby Vacuums
Tip
How To Replace a Belt on a Kirby Generation G3-Sentria Vacuum Cleaner
Greetings,
Below we explain how you can replace a vacuum cleaner belt on the Kirby Generation upright vacuum cleaner. All you will need to perform this repair is a new Kirby Generation Upright Belt, and some time. No tools are needed to perform this repair. This repair is the same for all Kirby Generation models including: G3, G4, G5, G6, Ultimate G, Kirby Diamond Edition, and the Kirby Sentria. The repair procedures have to be followed exactly in order for the vacuum to work properly. This should be done at least once a year even if the belt doesn't break, because these belts will stretch out over that year time period and will not work as well as a new belt would.
I hope that you find this video helpful. If you do, please be sure to rate this Tip as helpful by clicking the Thumbs Up Icon in the top right hand corner of the Tip.
Feel free to send me an email anytime if you have any questions on the repair of the Kirby, or any vacuum cleaner.
Video Repair on how to Change a Belt on a Kirby Generation Vacuum Cleaner;
Thank you so much,
Chris Jones
GoVacuum
on Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Change belt on Kirby heritage vacuum
It is the same as installing a Kirby Generation belt.
Here is a walk through:
Install Kirby belt and nozzle
800-775-6586
GpodVac com
Sep 15, 2014 | Kirby Vacuum Fan Heritage G3 G4 G5 Ult G...
How do we change the belt on our Kirby Vacuum Cleaner
Here is a link to a video explaining how to change the belt on a Kirby vacuum. It is at the bottom of the page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
Jun 02, 2010 | Kirby Heritage II Vacuum
How do you attach the belt for the roller-brush on a Kirby Generation 3, up-right vacuum-cleaner?
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Thanks for watching!
Chris J.
Jun 14, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Belt
I don't know where near you, but most local repair shops should have the belts for kirby.
Jun 18, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Vaccum
Rotate the square knob on the front of the attachment to the "Belt On" position (green marker). Insert your fingers in the attachment port (the round opening on the back where the "hook" is) and position the belt so it's centered and as high up as it will go (that's usually just below the center of the opening. THEN rotate the square knob on the front to the "Belt Off" position. You should feel the belt tighten up and the know harder to rotate.
TJ
Apr 29, 2008 | Kirby G5 Bagged Upright Vacuum
How do you replace the belt on the Kirby, Model No D50, Serial No. A442867
Generic problem for all Vacuums
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This is an older Kirby vacuum and the front brushroll section of the vacuum and the front brushroll section will come off, 1st you have to remove the front cover (the Kirby Emblem) and under that there is a Kirby spoon or hook and you need to dial off the belt off the belt shaft, once that has been done remove the bottom plate and un-install the Kirby brushroll, check to see if the brushroll spins freely, if it does go onto the next step, if not clean off the hair and thread from either end and then re-check the brushroll, if it still binds up then replace the brushroll and belt with Genuine Kirby belt and brush. Then use the dial to place the belt onto the Kirby spoon / hook. Once the belt is on the hook, install the bottom planter and place then housing of the Kirby on the vacuum and use the lever on the top to secure the fan housing dial the belt onto the pulley and you should be good to go.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Apr 21, 2008 | Vacuums
Im trying to replace the cloth bag on my Kirby G6. How do I release the belt that holds the cloth bag at the bottom of the assembly? It is grey and has teeth that grab when tightened on the bottom of the...
Kirby G6
Im trying to replace the cloth bag on my Kirby G6. How do I release the belt that holds the cloth bag at the bottom of the assembly? It is grey and has teeth that grab when tightened on the bottom of the unit.
There is a vinyl cover over the outside of the cloth bag and underneath the vinyl cover is a
ny tie that you have to cut off and replace with a new one and the cloth bag will slip off the bottom of the dirt cup @ the bottom of the cloth bag and remove the top cover and the bag should just come off, you can get the ny tie from any local vacuum cleaner dealer that does repairs or you can call the Kirby factory phone number listed below
Monday thru Friday
Apr 16, 2008 | Vacuums
I can't get the new belt on my kirby
I can't get the new belt on my Kirby
The Kirby Vacuum has a removable head and bottom plate and the belt is hooked on by a hook inside of the Kirby head of the vacuum. You need to slide the belt onto the Kirby brushroll to the center and the dial in front of the Kirby vacuum does rotate to the right – so @ this time you would dial the belt clockwise and the inside hook will pickup the inside belt and continue turning the dial / hook until it stops – look inside to see if the belt in on the fan shaft – if it is then install the bottom plate back on the vacuum and then install the head back on the Kirby or if it is newer the head is already on the motor assm.
Plug in the vacuum and if the belt stays on and the brushroll is tuning you have done it right – if not reverse the situation, unplug the vacuum and start over with the procedure. The hook will dial the belt onto the fan pulley if done correctly. Example: try to turn the dial on the front of the vacuum to see hoe it works and the way the dial will turn so that the procedure will be easier. The dial does turn hard when dialing the belt onto the pulley.
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
Kirby Ultimate G Bagged Upright Vacuum Logo
62 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
