SanDisk Sansa e200 MP3 Player Logo
Posted on Jun 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sansa mp3 player won't turn on
I just charged my player and added a few songs. When I go to sync more songs I have to reconnect the player, even though it is plugged in and connected, and now the thing won't even turn on. Any suggestions?
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Jul 06, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2173454
Points
14133
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
No songs can be added
The songs that you are trying to load are probably in the wrong format. Many WMA files (used by 90% of music services) have restrictive DRM licenses that will not allow you to play certain files on an mp3 player, even though they play fine on your computer. Also, the Sansa e200 does not play songs that are in iTunes format. If you stick only to songs that are in mp3 format, you will not have such problems.
If you are CERTAIN that ALL of your songs are in mp3 format:
-Tha Mp3 Doctor
Sansa Clip 2gb won't play songs
I would format the player from within the player itself - the directions are in the user's manual: If the formatting fails:
-Tha Mp3 Doctor
Can't see all my songs and can't delete songs
This happens because you are not using the right software to sync your music, please us this specific software that I am about to tell you to transfer the music to your MP3.
http://www.rhapsody.com/-software
Thank You!!!!!!!!!
Sansa clip mp3 pink
Could be a hardware issue requiring replacement, but try every "soft" fix first:
-Tha Mp3 Doctor
Stuck on the main screen!!! HELP!!
Unfortunately, in the state that it is in, the songs will be deleted, b/c all of the recovery methods result in all osngs being deleted. Sorry.
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
My player is messing up
or
-Tha Mp3 Doctor
Adding music to my sansa e250
you must use windows media player 10 or 11 to sync songs into the sansa. Make sure you sync it this way or else your songs will not go in properly.
Sandisk Sansa c150 2 GB MP3
Can you reconnect it to your PC and try to drop a song or two on the unit?
Frozen on Refresh Database
Take out the four screws on the back and pop out the battery then put it back on. Make sure you synced the songs properly. Add to the problem how you added your songs and I might be able to help.
Good Luck
Creating+ Saving Playlists and Doubled Songs
If you open the Sansa as normal Win file directory, can you see them? Is "Show Hidden Files" enabled in the file options?
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
