Question about Car Audio & Video
1507 v12 amp
One day i had it playing for like a hour and next thing i heard a pop come form it and then filled my car with smoke. Wont work anymore. This has also happened with 2 v12 707. Can anyone tell my why this keeps happening and how i can fix these 3 amps?
  • 109 Answers
Are you installing the correct fusing inline near the battery and are you sure that you're hooking the amp up properly? Sounds to me like something isn't being wired properly.
Posted on Jun 24, 2008
My car is overheating it has oil and water and it's not leaking, can anyone help me ?
the pop you heard was likely a hose burst. dont go by what water is in your overflow tank. need to check coolant at the radiator cap but only when its stone cold.
Jul 12, 2017 | 2002 Hyundai Santa Fe
Last week my 1984 nissan truck started smoking. It clears up and started smoking again the next day. That same day I put in brake fluid and power steering fluid before it started smoking. My brother in...
It's possible you overfilled the power steering reservoir or perhaps spilled some that leaked down on the exhaust manifold. That would cause a lot of smoke until it burned off.
Dec 17, 2010 | 1984 Nissan Pickup
CUR on alpine MRD M 605
check your ground and make sure you battery power is connect properly
Apr 14, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Amp messed up got 24 volts instead of 12 how to fix
Here is what I need you to do so that I can help you try to fix this. I need you to open up your amp take some pictures. I will need some of the overall view, then take two seperate picteures closer dividing the amp in half. They should look like one really big picture of the overall amp. Then finaly I need you to take some pictures of the problem. I am sure that witht the pop and smoke that you saw and heard you shold be able to find the problem really quick. With all of this and from the way is sounds this could be a really easy fix. onle last thing do you have a soldering iron, solder and a wet sponge.?
Apr 11, 2009 | Metrik Amplifiers MAX-1202 Car Audio...
Foul play or not
sounds like foul play but we must be sure, are the tires that were installed the exact same size as the rear? they have to be in order for the vehicles powertrain to run correctly, if they are not the same size then that is the reason for your problem. Where was the smoke coming from? Front of vehicle or under neath? and what caused the transdifferencial to go bad? did the tell you. do some research for me and we will get this taken care of. and ask them to explain how they know the trans differencial is bad and let me know.thanks
Feb 11, 2009 | 2004 Jeep Grand Cherokee
V12 MRV-1507 or Xplod? Amplifier - XM-ZR1252 good quality sound
Alpine is just a better brand in general. I have the older MRV-1507, sounds GREAT, i have had friends who has had the Explode line, but it was always a temporary system until they got something better, like the alpine or kenwood.
Aug 14, 2008 | Car Audio & Video
MRV - 1507 Question ...
The MRV-1507 is a two channel amplifier, below I've pasted important info from the manual:
Battery Lead (Sold Separately)
Be sure to add a 80 amp fuse as close as possible
to the battery’s positive (+) terminal. This fuse will
protect your vehicle’s electrical system in case of a
short circuit. If you need to extend this lead, the wire
gauge should be AWG8 or larger.
MRV-1507 ... 80A amp fuse
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
You can find a manual for this amp here:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=mrv-1507
Jul 07, 2008 | Alpine MRV-1507 Car Audio Amplifier
V12 / xplod issues questions
sounds to me like you have a poor ground, which is causing the amp to overheat. make sure you have as large a gauge wire for the ground as you can and make sure it has a good connection to metal this should solve your problem.
Dec 19, 2007 | Alpine MRV-1507 Car Audio Amplifier
Car Audio & Video Logo
118 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
