Question about Akai PT4298HD Rear Projection Television
TV wont turn on
I have a PT4298HD. The timer light will flash 10 times but wont turn on. I've switched outlets, I need help
  • 4,472 Answers
You can try unplugging it for 4 hours. Like I have said you have 2 options replacing the parts that are possibly bad. Which is common on these tv's. It will run 550-1000$. Your more economically viable solution is to replace the tv.
If you need further assistance please ask.
Thanks,
Lee
Posted on Jun 24, 2008
  • Lee A.
    Lee A. Jun 24, 2008
    are you trying to fix this yourself? Can you solder? If not then this would not be possible. It will cost more to fix then the TV is worth. I am sorry if you do not like the answer. but likeability is not a quality that a good solution needs to have.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 24, 2008
    You can get a 50" akai at circuit city for 500$.
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
I have no picture. After the power button is
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | Akai PT4298HD Rear Projection Television
RED LIGHT FLASHES 10 TIMES BUT WILL NOT TURN ON!
There might really be a problem with the unit. Try unplugging it out of the power outlet and plug it back in after 30 seconds. If your using a power box (voltage regulator), try plugging it directly to the outlet. If all nothing happens, see a local tv tech in your area. The unit could be damaged.
Nov 08, 2009 | Akai PT4298HD Rear Projection Television
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Set wont turn on
IF this is a dlp tv , the first thin you need to do is replace the lamp. J.D.W.
Jun 18, 2009 | Akai PT4298HD Rear Projection Television
Only the red light comes on
Whats up Wade?
This is DVD MIKE with Perfectimagess.Try this first .Unplug the TV for a while and press the On/Off button which is supposed to perform a "reset".After that, plug the TV back in. It should come on and the Timer light off. The picture and colors might be distorted, but pressing the Perfect Focus button on the remote control resolves this right away.
The problems is a black picture or the TV won't turn on. The Timer light stays lit even though no Timer has ever been set. The colors converge and the picture is pinched. I don't think all of the expensive repairs are necessary, My TV did go out after a week of non-use while out of town (I was out of town, not the TV). I don't know. I'll post more if I learn more. I hope this helps Wade,
Vacuum the dust off of the circuit boards and inside the cavity. TAKE CLOSE UP PICTURES OF THE CONNECTORS BEFORE DISCONNECTING FROM THE CIRCUIT BOARDS. (IF YOU HAVE TO.) TAKE OUT CIRCUIT BOARD MOUNTING SCREWS. AND REMOVE THE BOARDS.
VACUUM THE DUST. LOOK- SMELL AND CLEAN THE GROUNDS, AND CAREFULLY CLEAN THE BOARDS. ASSEMBLE. DOUBLE CHECK CONNECTIONS WITH PHOTOS,
AND PLUG IN, TURN ON AND HOPEFULLY ITS ALL GOOD.
WADE WORK WITH ONE HAND AS MUCH AS POSSIBLE SON!!
DVD MIKE
May 14, 2009 | Akai PT4298HD Rear Projection Television
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Akai pt4298hd rear proj tv
Unit may be in timer mode. Check menu settings
Apr 22, 2008 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
70 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
