Question about Cameras
My camera switches off after 3 seconds off going on. it says low battery when new batteries have been put in.
  • Anonymous Nov 17, 2008
    I too have recieved an error on my camera, I believe it says battery exhaustion. Anyone have any ideas. I have put new batteries in it, but it still shuts off after only a short time use.
  • 44 Answers
Camara needs a service.. it is not the folt of batteries..
Posted on Jun 24, 2008
Panasonic Lumix DMC-LS75---I have put in new batteries , yet it says " Please replace batteries" as soon as I turn it on and then switches off by itself. I have cleaned the battery terminals; it stil
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Check the contacts of the battery and in the battery compartment of the camera. They all should be clean and shiny. You can clean contacts with a dry cloth or cotton swabs. Never use anything sharp in or close by a camera.
Nov 23, 2014 | Panasonic Cameras
I just bought a Polaroid 300 and the low battery lights keep blinking, I've put 3 sets of new batteries in it and the lights still blink. Anything else I can do?
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
May 12, 2014 | Cameras
The camera (option m*5 pentax) got wet (on Songkran in Thailand). Now it works again except that it seems not to be able to load the battery. If I connect the battery charger while the camea is 'off'', the...
Normally when camera gets wet, first remove battery, use dry facial quality tissue to wipe water, keep camera in a/c so that whatsoever moisture inside camera evaporates due to low humidity in AC room for 24 hours . Take hair drier set in low heat mode holding minimum 6 inches away from camera blow warm air in battery compartment, mirror compartment, memory card slot for 2minutes each. Wait for cooling down to room temperature. Put battery switch on. It should work. Wet camera if you switching on main board get short due to flash voltage in side camera.
Sep 25, 2017 | Pentax Optio M85 Digital Camera
I hadn't charged my w330 Sony camera for a while ....I've only had my camera for 6 months...and it's warranty is 2 yrs. The camera is in good condition, yet when I charged my battery, and later put it in...
In order to avoid people using 3rd party batteries, electronics manufacturers have started putting smart chips in the battery packs. The camera interrogates the smart chip and if it isn't the Sony chip, the camera tells you "too bad."
In your case, since you have a genuine Sony battery (it came with the camera, right?), return to the dealer and have them exchange the battery.
Feb 27, 2011 | Cameras
I put in a new battery. When I switch to
New batteries should always be charged before the first use as they loose charge lying idle in stores. All batteries do.
Sep 17, 2009 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Camera says new batteries are dead
I found out how to fix it. (STEP 1.) Take out all of the batteries. (STEP 2.) Hold down the power button for 30 seconds. (STEP 3.) Put the batteries back in and you should be all set.
Dec 28, 2008 | Canon PowerShot A570 IS Digital Camera
Camera shuts off after a few seconds
i had that problem with another camera i toggled with the lens it went in and works like a charm. Dont be to gentile it will go in
Oct 08, 2008 | Samsung S630 Digital Camera
Samsung Digimax S500. Switch it in and when I go to take a pic is blacks out and will not on/off switch will not retract lens. Sometimes it says it has a low battery before switching off but I have put...
Sometimes 'new' batteries are not enough - put in a new set of high power *alkaline* batteries and try turning the camera on and off then.
Aug 05, 2008 | Cameras
Wont switch on
Some cameras have a bettery setting in the menu. You need to make sure this setting is set to the type of batteries you are using. Usually when you use akaline batteries and even if you put in fresh batteries but still get the low battery indication then your camera is set to rechargable (Ni-Mh). Ni-Mh has more power to it then alkaline so this is why you get the low indication.
Feb 11, 2008 | Samsung S1030 Digital Camera
Batteries
This happens with almost all digital cameras. You have a couple options. first you can buy lithium batteries, which are a little more expensive but last considerably longer in digital cameras.
The second is you can buy rechargeable batteries, which in my opinion is the best option because you can reuse them, and they also last really long in digital cameras.
the problem is, you just cant really put normal batteries in digital cameras. Lame but true
I hope that my answer was of help!
Jan 14, 2008 | Jazz JDC31 Digital Camera
Cameras Logo
66 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
