Question about Xerox DocuColor 3535 Copier
3535 hi i have network settings but since someone reset my nvm settings to clear a fault all the colours are out of fit
    Master:
  • 788 Answers
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Posted on Jun 24, 2008
Error code 042-326
IBT/Transfer belt problem, requires NVM access to reset.
How to reset 042-326
Jun 07, 2011 | Xerox DocuColor 3535 Copier
Xerox 3535
did you perform a reset which removes these settings? before doing such reset one should print out the settings.
see the manual in this address for instructions on how to re enter settings into the printer
http://download.support.xerox.com/pub/docs/DC_3535/userdocs/any-os/en/dc3535_en_customer_user_guide.pdf
system settings can be found on page 140 or 4-2 if looking at the markings in the pages.
Jun 20, 2008 | Xerox DocuColor 3535 Copier
Dc 236 machine has a fault code 010-320. fuser is new, lvps is new and so the small board, i dont know the name of that board... but still 010-320 is there... trying to reset the value of nvm from 2 to 0,...
Well since you know how to enter diagnostics. Go to DC132 and select all copier nvm. Do an all copier nvm initialization, it will correct any default errors in the memory.
You will just have to then reset things like the power save timers and I would also go in and do a dc604 registration adjustment.
Apr 18, 2011 | Xerox DocuColor 3535 Copier
Xerox 5225 fault code 010-320???
If you have a Xerox WC5225 with Error Code 010-320, then you have a fuser problem. The fuser is the heated item which bonds the image, just before it exits the unit. The machine monitors the temperature sensors and heating elements on this part.
The fuser is sold as PN 126K24980. It is easy to replace yourself.
Nov 23, 2010 | Xerox DocuColor 3535 Copier
Hello, after a NVM reset my ADF stop working and color where in wrong places. I resolve the color problems but ADF is not working is this activated by a NVM code? Regards, Hugo
How did you resolve the color problem? I am having the same issue on a Xerox Workcentre 24. After initializing the NVM, the auto-feeder does not work and the colors are off. How did you resolve the colors being offset?
Feb 02, 2010 | Xerox DocuColor 3535 Copier
Error 010348
over heting of fuser unit
can be reset by NVM read/write
744-003 set to 0
Jan 11, 2010 | Xerox DocuColor 3535 Copier
Reset fault code 010-348 xerox 3535 copier i have replace the fuser with new
wait until the machine is in the 'Ready' state, then on the Control Panel, select [9] and [AC] simultaneously. A message will be displayed asking if the Fuser Cartridge was replaced, select [Yes].
Jan 01, 2010 | Xerox DocuColor 3535 Copier
Error 116-365 on dc 3535
That is a hard drive error.
There is a job stuck on it.
Hold 4 + stop + powersave as you turn on the machine.
That will cause the Hard drive to initialize and should clear the job.
I have seen that caused by someone doing an internet print job.
You may want to unplug the printer cable and see if an incoming job is corrupting the network. I have even seen networks be hacked and the machines affected.
If that doesn't reset it. Check the connections to the hard drive.
When you do the hard drive initialization. Hold the 4 , the stop, and power save as you power it on , hold the buttons until you see the progress bar appears on the screen, then release the keys.
Jul 06, 2009 | Xerox DocuColor 3535 Copier
Xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
May 10, 2009 | Xerox DocuColor 3535 Copier
Error code 010-348
Hi go to system settings and then go to NVM location then type 744-003 and then change the value in the lower field to 0.
Jun 26, 2008 | Xerox DocuColor 3535 Copier
720 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
