I have a lawn mower,Tecumseh Prisma 37 PRI 156 with a fuel delivery problem. constantly starves for fuel after a few seconds running.
Have disassembled Dellorto carb several times , cleaned and blownout every orifice.
Fuel in bowl , needle valve not stuck.
What next?
? 7:33 www.youtube.com/watch?v=_dzcDZUh1MY May 10, 2013 - Uploaded by mountainbikekayak
But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
"Govenor hunting" caused by a lean condition ,carb is starving for fuel ! Dirt in carb or water,or out of adjustment ,or leaking throttle shaft ....usually it is a plugged low idle passage,that causes this condition,and is almost impossible to remedy,but a good cleaning might help .....does it only governor hunt at low idle ? If so thats the issue !
Sounds like a fuel problem. If you have a fuel bowl on the bottom of the carb take it off and clean and clean out the fuel jets that are in the bolt that holds the bowl on. Quite often that is the only problem. Make sure you put it back on with the gaskets in the right place or it could leak.
Immediate thought is that something got ingested into the needle feeding the carb. Might have to remove the carb and clean it out thoroughly to maintain fuel flow through the engine. Generally if it runs a few seconds and shuts down then it is running off the initial burst of fuel and then starving out for any more from there.
Have you Contacted Mountfield about a Manual? You can Contact them Using the Options at this Site Addy; http://www.mountfield-online.co.uk/contact?jssCart=13a24ca4de2a2610f7213de8a0539ffb .
For an Engine Manual you can Contact www.outdoordistributors @ 877-707-2787 or Contact Tecumseh @ 800-558-5402.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
