Question about InFocus LP 600 Multimedia Projector
Infocus mod.610/620 Lite pro
Unit runs fine for 15 to 30 minutes,then shuts down after a few minutes you can restart it and it works well for 15 to 30 minutes.
when it shuts down the light on the button is still on.It acts like it
just switches to the standby mode. Fan continues to run.
Any help appreciated.
Bob bobbytrue@msn.com
  • 5 more comments
  • bobbytrue Jun 27, 2008
    Re my infocus 620.Yes I tried a new lamp,same problem.
    Both fans working:;Cannot find a filter.
    The room temp is 75 degrees ,I cannot find the filter
  • bobbytrue Jun 28, 2008
    I have tried all the fixes that have been suggested to no avail.I have cleaned it out
    blown it out,at least it went 25 minutes today before it quit.Is there some sort of high
    temp.switch thacpould be the problem?Upon removing the front panel,I saw a white ceramic looking device about three eights by one inch long with a wire connector on each end.When the main power switch is turned on,this device shows arcing internally.Then the lamp comes on.I thought it could be a fuse but when checked with an ohmmeter it shows open or very high resistance.Will someone explain if this is normal?Thanks,Bob
  • bobbytrue Jul 09, 2008
    One person states that once you change the bulb,you must reset some
    timer?Any more comments on this timer and how to reset it and where it is located.
    Thanks,Bob
  • bobbytrue Jul 11, 2008
    I do not understand SYSTEM TIMER.Is this to show hours of lamp usage>
    But this should not cause the shutdowns ,should it?
    Any more comments or solutions?
    Thanks Bob
  • bobbytrue Jul 13, 2008
    I checked on the system timer and there is a factory flyer stating that the model620 no longer had a timer and that the overusage light was discontinued.But the lamp usage counter still worked.I did reset the timer to zero just in case.The timer showed 378 hours.I am still very puzzled so if anyone has a suggestion,I will be happy to try it.
    Bob
    Master:
  • 848 Answers
Try to upgrade firmware ........
Posted on Jun 27, 2008
  • 63 Answers
Clear out any dust that might accumulating in the vents and anywhere that gets hot.
Dont move the projector when it warm though or you might damage the lamp.
You might need to take the projector apart to get to where it needs cleaning, take all precautions about electric shocks.
Hope this helps
Andy
  • 6,487 Answers
Projector is overheating. Turn the projector off and let it cool for 30 minutes.
Clean the air filter and check all ventilation holes for blockage.
Hope that helps..........
    Champion:
  • 217 Answers
It may be reaching its max temp and shutting down to avoid over heating or popping the bulb. How is the air ventiliation and room temperature? You may also want to browse through the settings or check for a switch on it, to make sure it isn't set to go into a stand-by mode after such a short period of time.
    Brigadier General:
  • 3,614 Answers
Did you change the lamps before..?
  • micromaster
    micromaster Jun 27, 2008
    ooh.. ~
    okay.. i just make it clear if you have change the lamps.. once that you have change the lamp, you must reset the system timer. this method was made after you installed a new lamp on the projector.
    Thank you for using fixya..
My infocus 1503 works however once it is turned on the unit sounds as though it is ready to take off. The fan is very loud then after a few minutes it quiets down and then the fan becomes very loud again....
I own two of these projectors. You need to update the firmware to 1.03 which can be found on the infocus website. This solves the fan issues which also causes premature shutdown of the projector. Once you download the update, open it, there will be step by step instructions on how to do this procedure. I could not get this to work with Vista 64 so you might need to run this on XP or 7.
Mar 11, 2011 | InFocus IN1503 DLP Projector
The unit runs Ok for a few minutes and then shuts down.
Does it do this on just battery power or with an external power source? If on battery poer, then the battery if defective.
- Jim
Jul 20, 2010 | Garmin Nuvi 660 GPS Receiver
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
LP120 : fan stopped error
you can purchase and replace the blower assembly- part # 505-1917-00. it's tricky, but you can do it. find an infocus authorized service center form their web site to buy it.
Jan 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Infocus lp600
Clean your air filters. The unit will shut down if it overheats. Ensure that all the filters are cleaned and replaced regularly.
Oct 04, 2008 | InFocus LP 600 Multimedia Projector
Mod.620 shuts dowd.
Everytime that you use to change Lamp, the unit system timer must reset or setup again... You can see and change this option in the MENU SETTING using the remote control of the unit..
Regards,
micro
Jul 13, 2008 | InFocus LP 600 Multimedia Projector
sounds like either a power supply issue, which will cost more than the unit is probably worth. or the thermo- sensor may be flaking out, which may not be too costly to repair.
then there may be bigger issues but i would guess 1 of the 2 mentioned
Jun 25, 2008 | Office Equipment & Supplies
Infocus 4805 problem
Make sure that the lamp plug is properly plugged. 3 flashes indicate this or a faulty lamp.
Dec 19, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus LP 600 Multimedia Projector Logo
320 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
