Question about SanDisk Sansa e250 MP3 Player
Battery too low comes up on black screen
Sansa e-250 won't accept charge. Post it advice says to buy wall plug(110 volts) I did 20 bucks down the drain. More free advice, buy new battery...20 bucks down the drain still having the same problem screen says battery too low and shuts off even with new battery
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 26, 2008
VEC012POB Manual
Vector sold to Black & Decker who then sold to Bacchus. The only manual I find with the same number you show is NOT yellow and has no USB connection. It is charged by a 110 volt wall wart charger that plugs into a receptacle on the unit, or a 12 volt cigar lighter cable that plugs into the 12 volt port on the unit. Here's a brochure for the model number you provoided:
May 31, 2014 | JUMP START SYSTEM
I would like to recharge my sansa clip with a 110 volt household current adaptor. What do *I need?
My suggestion would be to look on eBay, at buy it now sellers,
This will give you an idea of what is available.
You can chose between really cheap and weeks in the post or quicker but still cheap.
I would get one that comes as a plug with a USB socket on it, some come with a cable.
Be warned, the cable will probably be good for charging only, not for connecting to put music on.
Otherwise any phone charger that has a plug that fits your player will be suitable.
See what your local electronics store has to offer.
Feb 15, 2011 | SanDisk Sansa Clip MP3 Player
How to test the voltage regulator
To test the voltage regulator, first you must have a FULLY charged battery in the bike. You'll need a good DVOM (digital volt ohm meter). Connect the DVOM across the battery, red lead to the positive post, black lead to the negative post. Put the meter's function switch in DC VOLTS, 20 VOLT range. Start the engine and bring it to a high idle. You should read 14.5 to 15.0 volts within a few seconds of starting the engine.
To check the output of the alternator, put your meter's function switch in AC VOLTS, 50 VOLT range. Follow the two wires that come from the regulator down to where they connect to the alternator either at the engine case or a plug. Disconnect the plug and look inside. You'll see two metal contacts in the alternator side of the plug. Here's where you're going to check for voltage. Start the engine, bring it to a high idle, and insert one meter lead into each contact. Since you're measuring AC voltage, it makes no difference which lead goes where. You should read at least 25 volts on a Sportster and 30 volts on a Big Twin.
If your alternator checks good but at the battery the voltage checks low. Replace the regulator.
Good Luck
STeve
Oct 10, 2010 | Harley Davidson FLHT Electra Glide...
Need diagram to diag not charging. thanks
To check your charging system, you'll need a DVOM (digital volt ohm meter). The first thing to do it to take your battery out of the bike and take it to an automotive parts house. Ask them to load test the battery for you. This will ensure that the problem is not the battery.
Now, put the fully charged battery back into the bike. Connect the red meter lead to the positive post and the black meter lead to the negative post of the battery. Put the meter's function switch in "DC VOLTS, 20 VOLT range. Start the bike and bring the engine to a high idle. The meter should read between 14.5 and 15.0 volts.
If it doesn't read this voltage, find the wires coming from the alternator on the lower left front of the engine. Follow the wires back to the round plug and unplug it. Look into the engine side of the plug and you'll see two metal contacts. Make sure these are clean. Put your meter function switch in AC VOLTS, 50 Volt range and start the bike. Bring the engine to a high idle. Put either of the meter probes on one metal contact and the other probe on the other contact. The meter should read 25 volts or higher.
If the battery test reads low but the alternator test reads correct, the regulator is probably defective. If the alternator reads zero voltage or low, the alternator stator is bad.
Good Luck
Steve
Aug 27, 2010 | 2000 Harley Davidson XL 1200 S Sportster...
The mp3 player won't charge when I plug it into the computer and my wife's won't accept any more playlist
I dont know about the playlist. But if the Sansa LION battery goes too low it shuts down. When you plug it into your computer to charge the player, It usually powers up so the computer can detect the hardware being plugged into the USB port and provide power for charge.
You need to plug in the USB cable from the player to the PC and perform a system reset - Press and hold for 20 seconds the power on button and the play button (>||). this should work you may try it on your wifes player?
Feb 06, 2010 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
Sansa e250 2Gb - No Charge - My PC no recognize my mp3
if you plug it in to the computer mabe the drive cant charge it in some computers some drives dont charge the mp3s it happened to me but try to connect it to different arias and if that doesnt work buy the wall charger hope it helps.
Jul 03, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
