Question about HP LaserJet 2300 Printer
Hp 2300 new cartridge printing black lines
Hi
We have just installed a new catridge, when it prints on a blank page there is a thick black line across te page, it appears to happen every rotation, inbetween in the middle of the page there is black smudge.
put the old toner in No problems.
Tried it in another machine the same thing.
does it need to be set up/installed.
how can you refill with micro chip.
THank you.
Regards
peter
  • 1 more comment
  • pohhop Jun 24, 2008
    Hi
    NO its a new cartridge.
    the problem is when you buy in GHana theres no return, simple becoause of counterfit ones.
    any thing that can be done?
    as experts, is there any problems with these printers? I'm thinking of importing some used ones.
    Regards
    peter
  • pohhop Jun 26, 2008
    Thanks for the comment
    these came from the UK from a recognised Dealer, and it an original.
    give me some prices on:
    2200,2300, 4050, 4650 colour and Black, 8100,
    where are you located?
    Regards
    Peter
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this a refillable cartridge your putting in?
    I don't recommend refilling them because they cause further copy quality problems.
    It could be that the cleaning blade from the new toner cartridge isn't working.
    It should be returned for replacement.
  • HP Master
  • 2,794 Answers
There good printers its just who you use to get the cartridges from. We sell some but there not refills and we have good prices if your interested.
Unlike Ghana our can be returned if they don't work.
Posted on Jun 24, 2008
Printer not alligning catridge
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!!!
Sep 15, 2011 | HP Photosmart C5580 All-In-One InkJet...
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
New Black cartridge installed. Only part of page prints.
I understand your concern and to resolve the issue you need to download and install HP smart web printing software. Click Here for HP Smart Web Printing software and select your operating system and download & install the software.
May 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
CATRIDGE ERRIOR
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below:
1. Please press the "Options" button 10 times. "Cartridges" should now appear in the display screen.
2. Press the "Left Arrow" button once, which then brings you to the "Self-Test" option.
3. Press the "Select" button once. You will hear a series of clicks.
4. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about ½-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 09, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
Lines across printed pages
I think you need a new cartridge.
Oct 24, 2008 | HP LaserJet 4 plus Printer
Printout blank
this is problem with cartigdes only just installed new one and see.
Oct 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP LaserJet 2300 Printer Logo
442 people viewed this question
Seeker5211
Seeker5211
